Leinbach Disc Harrow
/ Leinbach Disc Harrow #42
Gizmo36 said:
will take 150$ for them . They need a little work . I Have been going to rebuilt them and paint them just have not had time.
What Size dic harrow? 8?,7?, or 6? I am interested. Have 32 HP 4W Drive tractor?
Gizmo36 said:
I have rebuilt them and paint them And they are gone.
Shoot. I guess I forgot about this thread. I would have/should have bought that disk from you.
I did end up buying a Leinbach just recently. I got the seven footer. It does a good job. I like the screw adjustable gangs. Fit and finish were pretty poor I have to admit, but at least as good as a typical KK, etc. and cost less.
I imagine your 32hp 4wd would pull a seven footer like the Leinbach I just bought (my tractor is 45 hp 4wd). However, check your tractor's specs in regard to how much your 3 pt hitch will lift. My disk weighs 760 pounds and it is not a 'heavy duty' disk. I've seen and lifted a 6 foot disk that weighed a lot more. The max recommended weight for an implement that sticks out way behind the lift arms like a mower or disk is right at 900 pounds for my tractor. And you can tell when that 760 pound disk is back there.
So, even if your tractor can pull a disk, make sure it can also lift it and travel safely with it lifted. And remember, you lift is a lot. It goes up and down and gets swung around at the end of every row, and if its like my place, its bumpy too.
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
TANK MANIFOLD (A55745)
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
John Deere Z994R (A60462)
John Deere Z994R...
2014 Dodge Avenger Sedan (A59231)
2014 Dodge Avenger...
