Leinbach Disc Harrow
/ Leinbach Disc Harrow #42
Gizmo36 said:
will take 150$ for them . They need a little work . I Have been going to rebuilt them and paint them just have not had time.
What Size dic harrow? 8?,7?, or 6? I am interested. Have 32 HP 4W Drive tractor?
Gizmo36 said:
I have rebuilt them and paint them And they are gone.
Shoot. I guess I forgot about this thread. I would have/should have bought that disk from you.
I did end up buying a Leinbach just recently. I got the seven footer. It does a good job. I like the screw adjustable gangs. Fit and finish were pretty poor I have to admit, but at least as good as a typical KK, etc. and cost less.
I imagine your 32hp 4wd would pull a seven footer like the Leinbach I just bought (my tractor is 45 hp 4wd). However, check your tractor's specs in regard to how much your 3 pt hitch will lift. My disk weighs 760 pounds and it is not a 'heavy duty' disk. I've seen and lifted a 6 foot disk that weighed a lot more. The max recommended weight for an implement that sticks out way behind the lift arms like a mower or disk is right at 900 pounds for my tractor. And you can tell when that 760 pound disk is back there.
So, even if your tractor can pull a disk, make sure it can also lift it and travel safely with it lifted. And remember, you lift is a lot. It goes up and down and gets swung around at the end of every row, and if its like my place, its bumpy too.
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2021 Club Car Carryall 500 Electric Utility Cart (A59228)
2021 Club Car...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A59908)
2016 INTERNATIONAL...
