Loader Left side of loader not lifting
/ Left side of loader not lifting #1
Thumper1
Hello,
I'm new to tractoring so please forgive my ignorance, at least for a month or so.
I'm using a JD 4500 with a 460 loader, the left side of the loader dosn't seem to want to lift, like it's weak.
I re-built the lift cylinder trying to correct this problem, however, that didn't help. The good thing is I can add cylinder re-building to my list of can do's.
I was going to look at the control unit next but the thing is, even though I know what I'm looking at, I really don't know what I'm looking for. There are no leaks in the system, and it doesn't sound like there is a restrection in the line.
Truth is I need some help
Thank you in advance
Thumper1
/ Left side of loader not lifting #2
Welcome to TBN:D
I can't see the valve being a problem if the other side is lifting fine as you say-that only leaves the cylinder. I would recomend swapping the cylinders from side to side to see if anything changes. There are ways to test the cylinder also. Could one of the hydraulic tubes that cross the loader torque tube be crushed?
I'll give swapping the cylinders a try, I didn't see any crushed lines, however, two of them have been replaced, I know this because they don't have any green paint on them and the others do.
I'll look around for crushed lines and swap cylinders and post the results results.
/ Left side of loader not lifting #4
I'd also look at those two replaced lines--maybe even take them off, clean up the threads etc and re-connect. Make sure they are sized correctly (were they sourced via JD from the prior owner??). It doesn't take much (a little teflon tape??) to slow things down.
Thanks B8,
I worked my butt off today, I didn't have time to even look at the tractor, let alone as my wife would say "play with it". Where do they get that stuff anyway? I'm using the tractor to landscape and build her flower beds but if I have to work on it, I'm playing with it.
I'll give the lines a shot, I noticed when I lift the bucket, the left cylinder bounces a bit, not a lot just a few mm or so, I've always thought it had a air lock but I can't find where it would be locked up at.
Thumper1
/ Left side of loader not lifting #6
After you put the cylinder back on, did you stroke it completely both ways and hold it against the relief to push all the air out? If not, you probably do have air in it.
Kim
/ Left side of loader not lifting #7
x2 on swapping the cylinders to see if that isolates the problem. That should tell you a whole lot. Also, x2 on stroking the cylinder back and forth to the limit a few times and make sure your hyd fluid is topped off.
If you find that it's not the cylinder, I'd start by visually inspecting the fittings in the suspect circuit. I had a similar problem on my backhoe, which I traced down to a fitting that, instead of having a 3/8" opening in it, had a 1/16" hole in it. Big difference! You couldn't tell the difference from the outward appearance of the fitting. It was either a flow-restricting fitting or a manufacturing defect. I switched it out and voila! fixed.
Also, maybe check how evenly the cylinders stroke when one end of each is not connected. You could possibly be seeing some kind of bind in your loader.
Thanks for all you're help so far, wanted to get that out of the way so I don't forget.
No I didn't stroke the cylinder, I'm not sure I really know how to do that without running the other cylinder. Do I unhook both cylinders from the loader and work them that way? or do you mean for me to run the loader up as far as it goes then back down a couple of times? I'm trying not to be a complete moron here, I just don't know. I work on equipment and machines for a living, just not this type.
Thumper1
/ Left side of loader not lifting #9
Thumper; Just run the loader all the way up until it tops out and hold the lever until you hear the pressure relief open (will be kind of a squealing sound and the engine will load up), and then do the same lowering it. Do it a couple of times each way. That will push all the air out of the system and you won't hurt a thing. See if that doesn't cure you're problem.
Kim
/ Left side of loader not lifting #10
Kim
Good idea and this is the first thing to try. If this doesn't work, and Thumper doesn't find any kinked or crushed lines (don't forget to check out the hoses, Thumper...one or more may be deteriorating), then Kennyd's idea of swapping the cylinders is next.
Thumper, I'm pretty late to this thread..but when did you notice this problem? Was it from day 1 of ownership? Was it after a particular type of loader work?
/ Left side of loader not lifting #11
This could be overkill info. but when you are going to bring the loader down, make sure that the cylinders goes all the way in. It will probably lift the front end of the ground, that ok.:thumbsup:
Thanks Kim, I'll do that today when I go out.
Roy, I'm using my father in-law's tractor, kind of barrow with option to buy when he gets around to saling it. It's had this problem for at least the last couple of yrears. He doesn't use the tractor much and I'm sure he doesn't use the loader much at all, so I don't believe a big lifting job wouldn't have been on the menu as a cause for this problem.
I do have another question; how hard is it to install brakes on this beast, their marginal at best and I live on a hill.
Henri, not overkill at all, every little bit helps, I'm learning something everyday. Thank you
Thumper
/ Left side of loader not lifting #13
I had a similar problem when my tractor was fairly new. I took it back to the dealer and they rebuilt the cylinder. No improvement.
Finally they reseated the connectors from the tractor to the loader hoses and fixed the problem.
One of the connectors had become unseated and wasn't immediately obvious. Hope this helps.
I ran the loader all the way up and down a few times, it seemed to help a bit but the left side is still lazy, I'll try swapping cylinders tomorrow to see what happens.
/ Left side of loader not lifting #15
Thumper
Brakes are wet brakes and I'd be surprised if they were "worn out". What is the history of the tractor regards the brakes?
But should have good brakes, wherever.
/ Left side of loader not lifting #16
Did you hold it against the relief? You need to be sure you have all the air pushed out. You thought it seemed to help and if that is true I think you may still have air in it. Cycle it up and down a few more times and be sure to hold it against the relief valve a few seconds at the end of the stroke, and be sure you stroke it clear to the ends of the cylinder stroke both up and down, and was said, it will probably lift the front of the tractor. Unless you have some kind of restriction in a line or an internal leak in the cylinder, I can't see how one side can be lazy.
Is the loader twisted (sprung) and making it look like the left side is lazy? Park it on a good level surface and just raise the loader until it is off the ground and then measure from the loader to the ground and compare side to side. They should be the same. You need to have the air pressure in the tires (rears) the same and the tires need to be a matched set for this to be an accurate test.
Kim
