LED workshop lighting - the saga continues
   / LED workshop lighting - the saga continues #11
The conversion kits I used did require replacement of the tombstones on one side of the fixtures. I have since learned that there are LED bulbs available that do not require replacement of the tombstones. Although replacing the tombstones and cutting out the ballasts was no big deal, I would certainly go for the simplest solution if I was to do it again.
Well in another part of the shop I had two troffer style fixtures w/ 3@ 4' fluorescent bulbs (T12) per fixture and two ballasts per fixture that failed.
I bought 8 of the 4' LED bulbs (~$150) and they came with the replacement tombstones. This was excellent because two of the old tombstones had cracked. I've put 6 of the bulbs in the 2 fixtures. They are showing about 800 lumens at reading chair level, as bright as a well lit supermarket.
I wrote to Hyperikon and requested 4 more tombstones, which they are sending. I'll probably pull 2 LED bulbs out and use them elsewhere.
   / LED workshop lighting - the saga continues #14
Any pictures?
Brent 420 Auger Wagon (A50514)
Brent 420 Auger...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2006 Isuzu NPR 16FT Box Truck (A50323)
2006 Isuzu NPR...
2018 Maserati Ghibli Sedan (A50324)
2018 Maserati...
KUBOTA B26 BACKHOE (A51242)
KUBOTA B26 BACKHOE...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51694)
2020 Polaris...
