LED Work Lights
/ LED Work Lights
Hey Guys,
Sorry we've not been around looking much, we had
a major problem with the house about May 6th and
we are just finishing fixing everything.
TeamNH, I'll get a couple photos but the switches
I mounted on each side of the controls mounted on
the fenders. There is just enough room to mount a
waterproof switch there. I put one switch for the upper
lights and one for the lower lights.
I'll get a test set up in a week or so I'll show the lights
from the T2220 and then I'll show the lights from
the cab lights on our DX60.
/ LED Work Lights
Here's the photos of the switches, there is just enough room to install them in this position. After the wires were attached and we had to bend the lugs a little then we water proofed the switch by sealing it with liquid electrical tape. We put the waterproof boots on the top of the switches to finish the job.
I wanted to install the switches where they were within reach without searching for them. Hope this helps.
/ LED Work Lights
On our T2220 there are two plugs that are switch controlled
for factory work lights. We wired them straight, work fine.
/ LED Work Lights #27
Thanks alot! yes that will help greatly. I think try for the same spot. I would like to put them together thou, and maybe order the switch that is on the dash for the hazard lights. you know the black rocker with light. I want to see what i can find like that.
Thanks again!
/ LED Work Lights
I'll tell you now if your tractor is like mine you don't have room for a rocker switch, I just got these in. There is a inner fender that you've got to sandwich the switch between.
/ LED Work Lights #29
very cool idea and nice job with the switches
/ LED Work Lights #30
I had never heard of liquid electrical tape. May I ask where you find it?
2004 Ford F-250 Ext. Cab Service Truck w/ Liftgate (A59230)
2004 Ford F-250...
Tafe 45DI (A53317)
Tafe 45DI (A53317)
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
2007 Honda CR-V SUV (A59231)
2007 Honda CR-V...
2015 CASE 621F WHEEL LOADER (A58214)
2015 CASE 621F...
