Least Tippy Machine
/ Least Tippy Machine #41
The compact telehandler does great with the box blade on a SSQA to 3 point adapter:
/ Least Tippy Machine #42
I agree, if possible, buy a couple loads of dirt and begin the process of filling the holes. Make it a regular process like maintaining a gravel road. If that is not possible, hiring a doser may be a lot cheaper than looking for other equipment that may or may not be any safer. I have a L4701 and a box blade. They work great at filling holes. Best wishes, Larry
/ Least Tippy Machine #43
A thought..... Why would you consider selling you expensive tractor at a loss, to buy new tractor to solve your problem, when a day or two of work with a hired dozer would be a lot cheaper, and maybe after holes are filled with dozer you would find out that a new tractor is no better on property than one you sold.... Personally I would do dozer operation first, and see if present tractor would do just fine if there are no holes to fall into...
/ Least Tippy Machine #44
If the T650 worked so well why did you get rid of it or why not get another one?
/ Least Tippy Machine #45
Why not have a skilled experienced operator come over and use your equipment and dirt supply to fill the holes. This would be a cheaper solution than a dozer. Do you haven anyone in mind that might be willing to do this for you?
/ Least Tippy Machine #46
Or maybe give instructions or demonstration so you can do it yourself without accident or injury....
/ Least Tippy Machine #47
I thought orchard tractors were narrower so they'd fit between the rows.
Back in the day with "old school" Orchard tractors, they were setup to run under widely spaced trees on slopes, so they had shorter spindles and shorter, wider rear wheels and sometimes wider rear axles.
Modern orchard tractors are very narrow 60-120HP tractors on smaller frames (more like a small to medium L series) and can be tippy, they are setup to run down rows of fruit trees planted on 10-12' centers.
Aaron Z
2017 Hino 155 16ft. Box Truck (A64556)
2017 Hino 155...
2022 EZ-GO ELITE...
2016 BOMAG BW145D-5 SMOOTH DRUM ROLLER (A65053)
2016 BOMAG...
2018 Chevrolet Impala Sedan (A64557)
2018 Chevrolet...
2010 Chevrolet Express 3500 Dive Team Cargo Van (A64556)
2010 Chevrolet...
2010 CATERPILLAR 120M AWD MOTORGRADER (A63276)
2010 CATERPILLAR...
