Learning how
   / Learning how #1
OrangeToys
Platinum Member
SW Missouri
2016 Kubota M7060HDC
So I want to learn how to weld and use a torch. What is the best way, trail and error? I can weld a little but its not pretty and nothing fancy.
   / Learning how #2
See if there's a class at your area community college, adult ed or vo-tech school. For a small fee you can avoid a lot of trial and error, learn things that you might not know to try and learn from other peoples mistakes.
   / Learning how #3
Maybe run an ad in your local Craig's list for someone to give you one on one instruction. 4-hours with someone standing over your shoulder has to be about the same as a week in a class room with 20 to 30 other students, and one teacher. In the last few months I've helped a couple people, both of them said I really jump started their welding.
   / Learning how #4
I could help you if you are in SW Mo.. I am in Branson. I am no expert, but self taught over a period of many years.. but I can run a bead. If you are near and want to come here, I could give you a few hours to kick start you.
James K0UA
   / Learning how
James K0UA
Im in nixa :)
   / Learning how #7
Cool, I should be home friday thru monday.. Pm me if you want to get together..
James K0UA
Behold the miracle of TBN at work.^
How have you learned other things that you enjoy doing and feel like you are good at? Books? Videos? Self Taught? Classroom instruction? Everyone learns differently. You may consider a little reading and a little trial and error before you take a class or connect with James. This can help you know what you don't know... I.e. you can figure out what questions to ask.
   / Learning how #8
That's a good point !
   / Learning how #9
I tried that once at a CC. It was 90+% book work, with only a bit of welding at the end.
Maybe they were training welding inspectors, not welders. :)
Bruce
   / Learning how #10
the oxy-acetylene handbook by linde/union carbide is the best book i know of on the subject.i recommend it.while you are experimenting,keep the acetylene under 6 psi.
2012 Ford Escape XLS SUV (A51694)
2012 Ford Escape...
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A53426)
2005 INTERNATIONAL...
INDUSTRIAS AMERICA 435 HEADER CART (A51247)
INDUSTRIAS AMERICA...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
