Leaky brush hog motor, simple fix.
/ Leaky brush hog motor, simple fix. #1
RegL
Platinum Member
Northwestern CT
PT 1430
Last Fall, the motor started leaking around the cap that's on top. Terry sent me a new O-ring. The repair turned out to be pretty simple and would have taken less than 30 min. if it had not been for the two hours it took me to locate the O-ring that I put away last Fall so I would know right where it is. Darned if that don't keep happening to me these days. The first pic is of the top of motor. You just have to remove those six bolts and gently take off the end cap without disturbing the layers beneath.
Holding the end cap with defective o-ring stuck to it and another pic of motor with cap removed. You can see the groove around the outside edge where the new o-ring go's.
While I'm at it, here's a shot of the rod I used to replace the stop bolts at the brush hog swivel joint (swivel joint??).
And a pic of a little gizmo I picked up on Ebay for 60 or 70 bucks to move trailers and wood splitter around the yard. It works well and the price is right I think.
/ Leaky brush hog motor, simple fix. #3
Good job!
Hey, that little 'gizmo' for moving trailers around looks pretty useful. From whom did you buy it?
Sincerely,
Rob :)
/ Leaky brush hog motor, simple fix. #5
smartguyz said:
Good job!
Sincerely,
Rob :)
Someone on here has already built a trailer mover, using a quick-attach plate, a 2 in receiver, and a 2 in ball.
If you have a set of forks, just bore or cut a hole in the tip end and mount a ball when you want to move something.
/ Leaky brush hog motor, simple fix. #6
I considered the other options, PT receiver hitch or getting a blank plate and have one built, but at 60 bucks the clamp on one made the most sense. I have the hole drilled in one of my forks but again, this little clamp on is much handier.
/ Leaky brush hog motor, simple fix. #8
Don't forget abut the $20 bucks for shipping. $60 + $20 = $80
INTERNATIONAL 8100 SPREADER TRUCK (A63291)
INTERNATIONAL 8100...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
2006 Sea Ray Sundancer 31ft Boat w/ Loadmaster 28ft Tri-Axle Boat Trailer (A64557)
2006 Sea Ray...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
Little Standing Horse Statue (A65583)
Little Standing...
KUBOTA RTV X1120D (A65643)
KUBOTA RTV X1120D...
