Leaking quick connect
/ Leaking quick connect #1
dog13
Thorn Hill, TN
Kioti RX6620, CS2210
Hi Everyone,
The quick connect for my grapple has developed a leak. I've done a search, but the leak threads i've found were about the fitting leaking when in use. Mine leaks only when there is nothing connected to the QC, if i'm connected life is good and no leaks. The leak seems to be from the valve itself, almost as though the ball is not sealing completely. Not sure if this is a sign of a bad O ring, bad valve, or something else? Thought i'd check with the collective wisdom of the forum before i start throwing parts at it.
Thanks!
Al
/ Leaking quick connect #2
Male or female coupler leaking?
/ Leaking quick connect #3
If you have the standard quick connects there bad about seeping fluid due the the steel on steel sealing area. The poppet style seals better due to the use of Orings to seal instead of steel on steel. If you have the standard fittings I’d switch over to the poppet style. If you already have poppet type connectors then you may have a damaged o ring.
The female is leaking, and they are the standard quick connects. I did not realize they were just steel-steel on the mating surfaces, certainly explains why they'd be inclined to leak.
I was thinking if i switch out the couplers of going with the flat face skid steer style. Any feel for whether those are better than the poppet style?
I only have one hydraulic attachment (so far) so thinking if i was going to change type this would be the time to do it...
Thanks!
Al
/ Leaking quick connect #5
/ Leaking quick connect #6
There is a light spring that holds the ball against the sealing surface on the ag-type couplers. I have found that they don't leak if they are out in the sun and thus under more pressure, otherwise, they weep a little bit. All of them, at one time or another. Not a huge deal, a few drops, just a little messy.
BRADLEY MACHINE MINI VAC TRAILER (INOPERABLE) (A67714)
BRADLEY MACHINE...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
2005 INGERSOLL-RAND SD-116F TF  ROLLER (A69167)
2005...
2020 HAULOTTE 3522A TOWABLE ELECTRIC BOOM LIFT (A65056)
2020 HAULOTTE...
2016 Nissan Altima Sedan (A66738)
2016 Nissan Altima...
Metaltech Climb and Go (A64553)
Metaltech Climb...
