Leaking quick connect
/ Leaking quick connect #1
dog13
Thorn Hill, TN
Kioti RX6620, CS2210
Hi Everyone,
The quick connect for my grapple has developed a leak. I've done a search, but the leak threads i've found were about the fitting leaking when in use. Mine leaks only when there is nothing connected to the QC, if i'm connected life is good and no leaks. The leak seems to be from the valve itself, almost as though the ball is not sealing completely. Not sure if this is a sign of a bad O ring, bad valve, or something else? Thought i'd check with the collective wisdom of the forum before i start throwing parts at it.
Thanks!
Al
/ Leaking quick connect #2
Male or female coupler leaking?
/ Leaking quick connect #3
If you have the standard quick connects there bad about seeping fluid due the the steel on steel sealing area. The poppet style seals better due to the use of Orings to seal instead of steel on steel. If you have the standard fittings I’d switch over to the poppet style. If you already have poppet type connectors then you may have a damaged o ring.
The female is leaking, and they are the standard quick connects. I did not realize they were just steel-steel on the mating surfaces, certainly explains why they'd be inclined to leak.
I was thinking if i switch out the couplers of going with the flat face skid steer style. Any feel for whether those are better than the poppet style?
I only have one hydraulic attachment (so far) so thinking if i was going to change type this would be the time to do it...
Thanks!
Al
/ Leaking quick connect #5
/ Leaking quick connect #6
There is a light spring that holds the ball against the sealing surface on the ag-type couplers. I have found that they don't leak if they are out in the sun and thus under more pressure, otherwise, they weep a little bit. All of them, at one time or another. Not a huge deal, a few drops, just a little messy.
2018 JOHN DEERE 325G SKID STEER (A65056)
2018 JOHN DEERE...
2018 CASE 650M LGP CRAWLER DOZER (A65056)
2018 CASE 650M LGP...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A66734)
2025 BrushFox...
2020 PETERBILT 367 (A67714)
2020 PETERBILT 367...
2016 Dodge Charger Sedan (A66738)
2016 Dodge Charger...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
