leaking hydraulic fluid
/ leaking hydraulic fluid #1
6sunset6
SE NY
NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
Puddle on the floor. Bigger every day. Hose someplace on the FEL. Today was the day. Too windy to work in the woods. Started to take off the FEL to find the problem. Then I realized I could just pull the hoses out , plug them back in
outside the frame and push a little oil through the valve and watch for the leak.
It was coming out of a crimp on a curl line. Pulled out the hose, hmmm 1/2 , R17 , 3/8 mpt on one end , JIC 6 on the other . 45" long. Ahhh Went to the local auto parts guy. I knew he would not have the same hose, his 1/2 was stiffer. So I thought go 3/8 put it on the retract side . Probably will never notice. $50 all done Can't tell the difference. 5 year old hose. I have seen crimps leak before. I guess it's sort of hit or miss and if it's your hose ,it's your hit.
2019 Ford Explorer AWD SUV (A61574)
2019 Ford Explorer...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
2025 Hydraulic Drum Mulcher Mini Skid Steer Attachment (A61572)
2025 Hydraulic...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
Hydraulic Mini Excavator Attachment (A61572)
Hydraulic Mini...
generator trailer (A61569)
generator trailer...
