Leaking Hydraulic connects
/ Leaking Hydraulic connects #1
dmccarty
Super Star Member
Triangle Of North Carolina
JD 4700
Hello,
I have a drip/leak in one of my quick connect fittings on my power beyond kit on my JD 4700. What is wierd is that the leak is in a connector that is NOT being used. I have the back hoe on the tractor and the leak is from the connectors that I would use to allow the hydraulic oil to flow back into the tractor if the back hoe was not mounted.
There is a rubber cap that fits into the fitting but it does not stop the leak. I have tried to tighten the fitting without much success due to tight space and wrenches being to small. On the other hand the leak is from the INSIDE of the quick connect not a joint so I'm not sure anything is loose. The leak is a drip drip drip when the back hoe is being used. I guess the hyrdraulic flow to the backhoe triggers the leak.
In the past I have not noticed the leak since I have been working in dirt. Lately I have been working on my road and that is when I noticed the leak. The leak could have been there from day one as far as I can tell.
Is a drip normal from quick connects that are NOT being used? How in the heck do you stop the leak?
Thanks....
Dan McCarty
/ Leaking Hydraulic connects #2
The rubber cap is only to keep the dust and dirt out. There is an internal O ring that seals the connection when you 'de-couple'. Either the O ring is not seated correctly or has a nick in it (most likely). Some couplers (like the ones on my Case) can't be disassembled and must be replaced. Others can be fixed with only a new O ring. Try coupling a connection to the leaking one and then de-couple again - good luck
Steve
Thanks for the info Steve.
I thought about just disconnecting the backhoe lines into the leaking port but I did not do it. Duh! [smile} I can't imagine the O ring is shot. I keep the black caps in the disconnected ports at all times and the backhoe is almost always on the tractor. I think I have changed out the backhoe for a 3PH implement two or three times so the O ring sure ain't WORN out! /w3tcompact/icons/smile.gif And I can't image that I managed to nick it with that few changes. Hopefully, its just not seated correctly.
You would think if I had the smarts to THINK about trying to reconnect the hoses I would have had the brains to actually TRY the idea out! DUH! /w3tcompact/icons/smile.gif
Thanks again!
Dan Duh! McCarty
2007 Peterbilt 378 (A62679)
2007 Peterbilt 378...
2017 Nissan Altima Sedan (A64557)
2017 Nissan Altima...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
New/Unused Landhonor Hydraulic Quick Attach Auger (A65583)
New/Unused...
2016 Ford Explorerawd SUV (A64557)
2016 Ford...
