Leaking coupler
/ Leaking coupler #1
PedeStablesEden
LS MT225E
Ok, so I just installed a manual diverter valve. All the couplers and fittings were that bspp or bssp thread i forget the exact acronym. The implement hoses wet all npt threads. So i ordered a set of quick connects from Amazon in the correct 1/2 npt thread. When i connect them they seemed lose and I was right, they leaked like a siv!! When i hook up the male ends that came with the diverter valve they are tight in there. The diverter has all female couplers. Are the quick connect male and female side different from 1/2G to 1/2npt? I don't think so but I'm not sure. I'm thinking the Amazon ones were junk. Someone please help me as I'm about to burn this tractor to the ground at this point lol.
/ Leaking coupler #2
1/2G and 1/2NPT are not the same. Nor is BSPP and NPT. The "G" threads are BSPP and are straight threads where the NPT usually has less threads and are tapered threads. Get the correct fittings or they'll all leak. :rolleyes:
/ Leaking coupler
Not what i asked lol, I know there is a difference in threads, I'm asking about the other end of the fitting. I have two sets of quick connects, one threaded with bspp, the other npt. Are the female part that accepts the male part where they push together both the same? My female connector is bspp, the male end on the line is npt, should they connect together fine?
/ Leaking coupler #4
If the connectors are the same series or style then yes the nipple and coupling should be the same irregardless of thread size or style.
You may have to confirm they are same series since I think some will look very similar and connect but they are not the same and will leak
/ Leaking coupler #5
  • high_pressure_quick_release_couplings.pdf
  • thread_guide.pdf
INOP/NON-RUNNING EZ - GO Golf Cart (A65579)
INOP/NON-RUNNING...
100 Gal Fuel Tank (A65643)
100 Gal Fuel Tank...
2012 DODGE 2500 RAM (A65643)
2012 DODGE 2500...
2015 Global M3 Street Sweeper (A64556)
2015 Global M3...
Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
Warren Power...
(2) Firestone Tires (A65640)
(2) Firestone...
