lead substitutes
/ lead substitutes #1
momark
I have heard vaious theories and opinions concerning the need for lead substitutes, or the lack thereof. Just wanted to get some of you guys' opinions, as you seem to be quite a knowledgeable bunch of folks. 1963 Ford 4000 Gas.
Thanks for any info,
mark
/ lead substitutes
mark
/ lead substitutes #3
Has hardened valve seats.. besides.. tetra ethyl lead wasn't valve lube.. it was octane modifier to prevent spark knock... gas was way low octane in the 1950's...
Soundguy
/ lead substitutes #4
Soundguy
/ lead substitutes #5
Waste of money.
If you already have hardened valve seats, you are good to go.
If you don't have hardened seats, it will cost you more in lead additive prices that what a valve job would cost you - just run it without until it needs a valve job in 5000 hours or so, & you will have saved money.
Considering leaded gas has been off the market for several decades, likely your tractor has been runnig on unleaded for quite some time.
--->Paul
/ lead substitutes #6
Waste of money.
--->Paul
/ lead substitutes #7
I have a JD 1010 which I believe is early 60's vintage my Dad bought about 12 years ago. After running it one or two years on unleaded fuel it started running very rough and missing allot. Started mixing lead additive and Marvel Myestry Oil with the gas and after a year of use it started running excellent. I don't find the lead additive to be very expensive, it only takes about 1 ounce per 5 gallon and the cocktail I use also includes 2 ounces of Marvel per 5 gallon. This same mix goes into my JD 52B also.
/ lead substitutes #8
/ lead substitutes #9
I'd wager the MMO is what helped you.. not the lead substitute.. here's why.
#1.. tetra ethyl lead was not added for valve lube as the wive's tail goes.. it was an octane modifier to prevent spark knock ( pre-ignition).
#2 The MMO IS an upper cyl lube. My guess is you were getting sticky valves, and the MMO helped free them up.
#3, and most important. If your unit didn't have hard valve seats, and the seats had eroded in the time that you were using unleaded gas and no lead substitute, then when yuo started using the lead substitute again.. do you think the valve seats would have megically healed, and the erosion was gone just by you adding lead substitute in?.. just ain't gonna happen. Most likely, the MMO, and the lead substitute both have a lube compound in it, and that was what helped. As a test.. you could just try running the MMO and see what it does... Also.. check your technical manual.. if it had hard valves seats 9 probably did ).. then it was good to go anyway.. besides.. as mentioned.. TEL wasn't a valve lube.. etc.. If you do continue to use the lead substitute.. post the brand name.. I'll see if they are selling any stock /forums/images/graemlins/wink.gif
Soundguy
</font><font color="blue" class="small">( I have a JD 1010 which I believe is early 60's vintage my Dad bought about 12 years ago. After running it one or two years on unleaded fuel it started running very rough and missing allot. Started mixing lead additive and Marvel Myestry Oil with the gas and after a year of use it started running excellent. I don't find the lead additive to be very expensive, it only takes about 1 ounce per 5 gallon and the cocktail I use also includes 2 ounces of Marvel per 5 gallon. This same mix goes into my JD 52B also.
)</font>
/ lead substitutes #10
Soundguy
)</font>
/ lead substitutes #11
I suspect you are correct that the MMO is doing the trick and the lead probably isn't needed. The old timer that lives across the hill and works on my tractors for me started me on the MMO when the valves were sticking and I'm not sure how I got started on the lead. However since my brother gave me two bottles of substitue that each mixes 320 gallons it has been added for many years now and I have enough for another couple years.
/ lead substitutes #12
/ lead substitutes #13
</font><font color="blue" class="small">( However since my brother gave me two bottles of substitue that each mixes 320 gallons it has been added for many years now and I have enough for another couple years. )</font>
Sounds expensive to me - but then I would run that fuel through my 4 gassers in about 6 months..... /forums/images/graemlins/wink.gif
--->Paul
/ lead substitutes #14
--->Paul
/ lead substitutes #15
I have put thousands of hrs on various models of older gas tractors using unleaded gas with no additives with no valve problems so I'm of the opinion that lead subs are a waste of money.
/ lead substitutes #16
Since Im in the market for an old tractor Ive given this some thought and wanted to run this by you all: At least 2 mfgs offered mdls in gas and propane. I figure theyd use the same motor for both fuels. If you run propane then there certainly wouldnt have been any additives for the valves. I would think then that running unleaded would be OK as they were originally setup not to depend on lead in the fuel. Am I wrong?
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63689)
2017 Yale GLC050VX...
3PT 10' Rolling Cultivator (A60462)
3PT 10' Rolling...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
213065 (A64276)
213065 (A64276)
