LB1914 floor
/ LB1914 floor #1
Tom_W
Wallingford, Ct
Kioti 1914 TLB kl1210 loader and a smc 65a backhoe (same as rhino)
My floor around the rubber mats were wearing through the paint. Can't have that! I picked up some Duplicolor "spray in bed liner" in a spray can. I masked it off and roughed it up with sand paper and sprayed it on. It appears to be tough stuff. I have to wait until tomorrow to try it out. I'm not sure if I'll put the mats back on as dirt collects under them and they are a pain to get off or on. I almost forgot, I also did the pedals. I figured it couldn't hurt.
/ LB1914 floor
another
/ LB1914 floor
yet another
/ LB1914 floor
and another
/ LB1914 floor #5
Nice work. Looks real good. Are you sure you don't want to put the mats back? G
/ LB1914 floor
Thanks. Well I haven't decided whether to put them back or not. Now that it's coated under where they go, it's less likely that it will rust from the dirt and rocks that build up under them so there's still a good chance that they'll go back in. It's raining here today so I won't be taking it out to play(er work).
/ LB1914 floor #7
Tom, you did a great job on that. It looks really good. I would think that if you don't want the pads back on, it might last longer for the same reason of dirt/sand rubbing off the coating. It sure looks good enough to leave the way it is. Of course, if that little bit of cushion from the mats makes a difference? Thanks for the pics. John
2019 DITCH WITCH TOWABLE VACUUM EXCAVATOR (A63276)
2019 DITCH WITCH...
2004 Ford Ranger (A62180)
2004 Ford Ranger...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63118)
PENDING SELLER...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
10 Chains & 5 Binders (A62183)
10 Chains & 5...
2011 Dodge 2500 Service Truck (A63116)
2011 Dodge 2500...
