LB1914 Brake issue
/ LB1914 Brake issue #1
CTaylor
Christiansburg,Va
LB1914
Hi folks, I'm new to this forum as I'm experiencing my 1st issue with my lil' Kioti after owning it for 10 years.
My brake 'sticks' anytime that I use it. I either use my heel or reach down w/ hand to pull it back and it releases.
Any thoughts?
Thanks
/ LB1914 Brake issue #2
Does your LB have grease nipples in the pivot like my DK? If so, have they been lubed?
I'm going to trace everything that I can[moving part-wise] hopefully this evening to see what all there is. I'm uncertain but don't think that there are grease nipples. It has done this in the past but w/use it would stop on it's own. That isn't the case this time and between hunting season and the holidays I just haven't had time. Need to do something before any snows arrive!
Thanks
/ LB1914 Brake issue #4
Look closely under the right foot panel; I believe you'll find a grease zerk on the tube through which your brake shaft operates, at least there is one on my 3054
Thanks for the replies, as soon as I can either get home in daylight hours from work or the weekend arrives I will figure this deal out and either grease or lubricate if there are no fittings.
Now on to my next issue: Front tires[industrial style] won't hold air anymore in the cold months[even when just sitting]. They are about 10 years old and I've never punctured them. Tread is decent. Put inner-tubes in them? Or replace? Inner-tubes scare me as I am always clearing land which leaves small sapling stumps everywhere but as mentioned above-I've never punctured one. Experiences with tubes??
Thanks
/ LB1914 Brake issue #6
If the tires are good try the tubes first.
I have a tube in 1 front tire due to a small cut in the sidewall.
I put a tube in several years ago and have had no issues since.
/ LB1914 Brake issue #7
It might be worth changing out the valve stems (cheap and easy) before you try the hard stuff.
2016 Ford Explorerawd SUV (A64557)
2016 Ford...
New/Unused Wolverine 48in Mini Combination Bucket (A65583)
New/Unused...
2022 EZ-GO ELITE...
VICON ROTOFLOW SPREADER (A63291)
VICON ROTOFLOW...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
