LB1100
/ LB1100 #1
Dgut615
LS4041
Anyone use LB1100 on a R4041 LS tractor. Website calls for 2101 but found a used unit cheap
/ LB1100 #2
Don't have an LS, but I use a smaller backhoe on my 5000 series Deere and it works just fine. You will likely need to adapt the subframe to fit your larger tractor
/ LB1100 #3
If you can make a mounting to fit, a smaller BH works well on a larger heavier tractor.
Back before we could afford a real hoe, we had a little 3pt hoe from a 18 hp tractor that we used on our big category II 3pt JD. On the little tractor I alway worried it would tear up the tractor. On the big one, there was no chance that little hoe would hurt the tractor, and so it turned out to work real well. It didn't bounce around so much and that was probably good for the BH as well. I did have to remember to turn the draft control off.
rScotty
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-350...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
KMC 6-36 (A64119)
KMC 6-36 (A64119)
UNUSED IREV HIGH END TWO-WHEELED ELECTRIC VEHICLE (A64281)
UNUSED IREV HIGH...
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2021 Chevrolet...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
