Lazy Way to Fix Cart Tire Hole too Big for Plug?
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #1
Suburban Plowboy
FL
Kubota L3710
This isn't about a tractor, exactly, but I have a tractor, so I feel I should be allowed to cheat.
I have a gas EZGO with a big hole in a tire. It was patched with a plug long before I got the cart, and it held air for years, but then it started leaking. I redid the patch, and it's not working out.
Is there anything I can do other than yanking the tire and taking it in for a hot patch? I'm too lazy to wrestle it off and back on the rim.
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #2
If the hole is too big for a plug, and a patch has failed, maybe it's time for a tube and/or a new tire?
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #4
I'm.a big fan of tubes but the quality of tubes can be suspect these days.
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #5
I’ve double plugs holes before. Use the red super sticky plugs. If it held with one plug for a while it might work.
I guess I can try double-plugging, but maybe I should just pull it off and pay a guy $15 to put a real patch in there. Always fun to try to beat the system. Thanks for the help.
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #8
How much tread is left?
Talk to your local tire shop and ask then when they are foaming some tires, and bring yours in too. Or perhaps all 4 tires.
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #9
on atv's we have put upwards of 15 plugs in a tire, then set the plugs on fire, till they melt back in the hole. works better than you think
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #10
Spray foam?
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
Head Gate (A57454)
Head Gate (A57454)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
Pickup Truck (A59230)
