Lazy Way to Fix Cart Tire Hole too Big for Plug?
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #1
Suburban Plowboy
Veteran Member
FL
Kubota L3710
This isn't about a tractor, exactly, but I have a tractor, so I feel I should be allowed to cheat.
I have a gas EZGO with a big hole in a tire. It was patched with a plug long before I got the cart, and it held air for years, but then it started leaking. I redid the patch, and it's not working out.
Is there anything I can do other than yanking the tire and taking it in for a hot patch? I'm too lazy to wrestle it off and back on the rim.
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #2
If the hole is too big for a plug, and a patch has failed, maybe it's time for a tube and/or a new tire?
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #4
I'm.a big fan of tubes but the quality of tubes can be suspect these days.
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #5
I’ve double plugs holes before. Use the red super sticky plugs. If it held with one plug for a while it might work.
I guess I can try double-plugging, but maybe I should just pull it off and pay a guy $15 to put a real patch in there. Always fun to try to beat the system. Thanks for the help.
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #8
How much tread is left?
Talk to your local tire shop and ask then when they are foaming some tires, and bring yours in too. Or perhaps all 4 tires.
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #9
on atv's we have put upwards of 15 plugs in a tire, then set the plugs on fire, till they melt back in the hole. works better than you think
   / Lazy Way to Fix Cart Tire Hole too Big for Plug? #10
Spray foam?
1964 Mercedes-Benz 190D Car Sedan (A56859)
1964 Mercedes-Benz...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
20ft Driveway Entrance Gate with 2 Columns (A57454)
20ft Driveway...
2002 Godfrey Sweetwater Pontoon Boat (A57453)
2002 Godfrey...
Bobcat S740 (A57148)
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A57453)
2007 Isuzu FTR...
