Laying flexible pipe with subsoiler
/ Laying flexible pipe with subsoiler #1
TNhobbyfarmer
Middle Tennessee
Kubota L3430 Polaris Ranger 500
I think I have seen threads talking about this subject. Anyone ever done it? If so, can you elaborate on the setup you used and would you recommend it? Pictures if available would be great.
/ Laying flexible pipe with subsoiler #2
There have been several threads on this site about doing just that, with lots of pic's. Have you tried doing some searches, here and maybe in the "Projects" forum? Shouldn't be too hard to find some.
I'll be honest. I've never been very good/lucky searching for old threads. I guess a little laziness might factor in the equation as well. Maybe someone with some knowledge of the subject will see this and respond.
/ Laying flexible pipe with subsoiler #4
/ Laying flexible pipe with subsoiler #5
I simply made a prepass with the subsoiler to ensure that the trench was open with no roots, rocks, or other surprises. Then used a short piece of chain bolted to the end of the pipe and pulled the pipe through on the return trip. I had the pipe laid out and a helper to insure taht the pipe fed into the tranch properly. I wasn't worried about maintaining a fixed depth or slope either. Pull was around 100' at 14 - 16" deep.
/ Laying flexible pipe with subsoiler #6
That's an interesting way of doing it. So the pipe was dragged through the ground while you were pulling it?
The way I've always seen it done is with a subsoiler making a pass with the pipe located over the SS in a big reel and the ground pulling the pipe through the SS and getting buried. I've never done it, just see youtube vids of it.
/ Laying flexible pipe with subsoiler #7
When I was a kid my dad did it this way and buried 1000 ft of pipe in one pull. It worked well but we had a hump in the pipe somewhere in the 1000 ft and it would freeze if we had a long spell of temp's down in the teens. I would make a gadget to check for how deep the pipe is. An iron bar with a little "v" welded to the top so it would catch the pipe. Just a thought.
I don;t think this would work if you had to do through a low spot with a high spot on each side. The pipe would be pulled up and freeze. Ed
/ Laying flexible pipe with subsoiler #8
I have been kicking around the idea of building a 4" shoe to bolt on the back of my JD 10A subsoiler. The 10" wide "laser tip" with the mole ball opens up a large channel.
/ Laying flexible pipe with subsoiler #9
Any chance you might have a picture or link to this laser tip or mole ball?
/ Laying flexible pipe with subsoiler #11
I have not used a subsoiler but I have used a single bottom plow many times to run pipe that I want to bury. I just did it two days ago. I ran 100 feet of 1 inch gas line and did not want to go very deep because it was over a septic field. The single bottom plow was perfect. trench was about 6 to 8 inches deep with minimal shovel work. Hardest part was uncoiling the pex gas line. From set up to backfill by myself was probably only around an hour and a half. I have also used this method to run water lines but I always winterize them in the winter. I would say this would work well up to a 2 inch outside diameter pipe/tube for a small single bottom plow.
/ Laying flexible pipe with subsoiler #13
There are lots of ways to lay your pipe but the simplest is to get the pipe layer attachment.
Run your subsoiler with the pipe attachment in place both ways to ensure no obstructions in your path.
Get a buddy to help feed the pipe and have at it.
Doing the steps above my friend and I laid 200' of 1" field pipe in 30 minute including a stop to splice the 2 rolls together in the middle.
The pics are before I ran the tractor over the line to knock down the berm we made.
You can see the project manager inspecting the job.
Because the start point was close to a footing I used the post hole digger and drilled 2 holes where I was going to start the pull. That got the pipe down to depth and the only shovel work I needed to do was filling in around my valve cover.
PS - JD no longer stocks the Mole Ball.
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
INDUSTRIAS AMERICA 2426 - 10' OFFSET DISC HARROW (A64277)
INDUSTRIAS AMERICA...
2022 EZ-GO ELITE...
2020 KENWORTH T880 DUMP TRUCK (A65054)
2020 KENWORTH T880...
2004 Chevrolet Silverado 2500HD (A66408)
2004 Chevrolet...
2011 18ft. Maxey Flatbed Utility Trailer (A64194)
2011 18ft. Maxey...
