Laurin Eclipse Cab for BX25
/ Laurin Eclipse Cab for BX25 #1
Jeff H
South Jersey
Kubota BX25D
There has been some talk of the Laurin Eclipse cab here.
Does anyone out here in TBN actually have one? I would hope that someone that actually has one to share some pictures and experiences with us.
/ Laurin Eclipse Cab for BX25 #2
I do not, but a call to Laurin in quebec will get you further along.
I know that laurin exports their cab
The Kubota M8540 orchard tractor is the one that has an eclipse as standard equipment with a pressurised cabin
/ Laurin Eclipse Cab for BX25 #3
Thank you. I have conversed with Laurin via email. But I would really like to talk to a fellow TBN'er that owns one. And if someone is in my area I would love to drive out and look at one in person.
Does anyone out here in TBN actually own one?
Well Laurin had been the only hard cab that accomodated the backhoe on the BX25.
It looks like Curtis has just introduced one also. The press release is from the end of December 2009. From the extremely small picture it looks a little less "deluxe" than the Laurin cab, hopefully that translates into lower price that more of us can afford.
Kubota BX25 Series (NEW!!)
News
/ Laurin Eclipse Cab for BX25 #7
http://www.tractorbynet.com/forums/kubota-buying-pricing/156901-m59tlb-laurin-cab.html
I have an EX on an M59. Above link is factory pictures. Extremely well built. Excellent heat. Rather pricey. I think the sound deadening within the cab could be signiifcantly improved. I have a full size MF with a factory cab on the farm. When you close the cab on the MF the engine sound level drops. I would say the level stays the same or increases when you close the door on the Laurin Cab mounted on the M59.
/ Laurin Eclipse Cab for BX25 #9
/ Laurin Eclipse Cab for BX25 #10
They all look like they add considerable amount of weight to the top of the tractor. Does this make them more top heavy and thus more prone to rolling over? :confused:
/ Laurin Eclipse Cab for BX25 #12
you might be onto something with the top heavy idea, prolly why kubota does not offer a cab on the 23-24-25 series with out resizing bigger or wider tires
/ Laurin Eclipse Cab for BX25 #14
The problem I see with the Simms cabs is they're really, really expensive for what you get. The Laurin is only a little more expensive when optioned out, but of significantly higher quality from what I can tell, so seems to be a much better value than the Simms.
The Curtis cabs are much more reasonably priced, and constructed similarly to the Simms. The issue for me is that when I was looking last year, Curtis did not have a model for my machine, but for the amount of time I'd want a cab, I'd much rather buy a lesser priced Curtis. If Curtis never bothers to develop one for my machine (and they may not due to the factory cab option), then I may end up with a Laurin at some point.
I really hate plowing snow during a 2 or 3 day snow event with the temps at 10* or lower.
Anyway, a Curtis cab could be optioned out at a significantly lighter weight for a BX if you only really wanted it for winter use, and should be much easier to remove doors/panels for summer use.
2015 Global Environmental Street Sweeper (A64553)
2015 Global...
ACETYLENE AND OXYGEN BOTTLE (A68842)
ACETYLENE AND...
Case SV300 High Flow Compact Wheel Loader Skid Steer (A66734)
Case SV300 High...
20 Ton Air/Manual Hydraulic Bottle Jack (A64557)
20 Ton Air/Manual...
2015 CHEVROLET TAHOE SUV (A66091)
2015 CHEVROLET...
X (A68191)
X (A68191)
