Lateral Sway adjustments
/ Lateral Sway adjustments #1
RoyJackson
Rest in Peace
Bethel, Vermont
John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
Question for y'all...
How much sway (side to side) is allowable, practically speaking?
I've never adjusted my sway links. The aft end of the 3PH mower (a Befco C-30 60") moves ~ 6" or 7" side to side....especially when reverse cutting. The lower links don't hit the tires, but the cotters pins in the sway links come mighty close.
A while back (on TBN, but another forum) John Miller III said no sway in transport (raised) condition. His concern was the "tail wagging the dog".
However, I'm more concerned about just reverse mowing. I've got to do a fair amount of that due to how my property slopes.
The mower came hooked up to the tractor. I mowed with it two or three times last season before I unhooked it to rig up the rear blade. I didn't see any need to adjust the sway links (although that may have been ignorance on my part), although the blade did tend to drift sideways (while at transport height), especially if the moldboard was angled for pushing snow. I attributed the movement then to the weight distribution of the blade (an ancient 6' blade).
/ Lateral Sway adjustments #2
Hmmm....interesting question. I don't know what the correct answer is, but I can tell you what I do. I loosen the sway links for removing/attaching implements and then snug them up for use. I do not "over tighten" them, but I ensure they are snug and that there is little drift from side to side. I'm pretty sure I remember reading on the board here (a long time ago) that there are a couple of implements that "they" recommend you leave a little play. Don't recall what they were, just that when I read it, I didn't have them!! /w3tcompact/icons/wink.gif/w3tcompact/icons/smile.gif
Kevin
/ Lateral Sway adjustments #3
I can't say what the "proper" way is, but I always did it like Kevin; didn't want anything swinging back and forth back there.
/ Lateral Sway adjustments #4
Roy - I'm new here so take what I say with a couple grains of salt. When I took delivery of my 4200 with 5' finish mower the dealer explained that mowers shouldn't have much sway. Other implements like plows should have sway. There are a couple holes in the sway bars that are "slots" that will give some sway, others are round holes that won't. When you put your mower on you may have put the pins in the wrong holes. Check to see if that is the case. Good luck, Bud
/ Lateral Sway adjustments #5
You want a few inches of sway at the far end of the mower or brushcutter. Think of what will happen when you nudge an immovable object. You have a big lever acting on your 3pt arms. Your better off allowing a bit of sway to compensate for that. At least thats what the old timers always have told me. It gives you a small amount of reaction time before you break something. As long as nothing is hitting the insides of your tires I wouldnt worry about it too much. You dont want it sloppy though.
You definitely want sway when you have a ground engaging implement. There are plenty of hidden joys that will gladly stop your tractor in its tracks under a few inches of topsoil.
/ Lateral Sway adjustments #6
Roy, I'd say little to no sway. Otherwise, your getting additional wear on all the support points and tend to not be sure where the edge of the mower is at any particular time. I'd think that would make mowing near objects such as trees, fences, etc also more difficult. A slight amount, something like an inch or so would probably be OK.
/ Lateral Sway adjustments #7
I have noticed that I cannot remove all the slack from the system as a whole. But if I don't tighten the 3PT arms to remove the slack in them, any time I backup with the mower on the ground, the mower will steer itself (usually toward a tree et al).
/ Lateral Sway adjustments #8
I tighten mine to where the lifting arm has no more than an inch of side movement after the implement is attached. The main reason is that when I am mowing on a side slope, my 6' rotary cutter will swing pretty far down slope if there is much travel allowed.
/ Lateral Sway adjustments #9
Attached is the "check chains" setup I have used for years to keep the mower (and same on my brush hog) mowing level. To use this setup you must have a flexible top link connection at the mower and merely lower the 3-pt control to the lowest position. On my brush hog, I don't have the turnbuckles since the height adjustment is less critical. With this setup, unless mowing on extremely unlevel ground, you are virtually assured of level mowing. Just drop the 3-pt control all the way and mow.
/ Lateral Sway adjustments #10
Check the owners manual of the implement you are using. I know there are exceptions to every case, but all the implements I own give recomendations for implement sway. Some require sway others don't.
I did check the Befco manual. That's what got me started on this thread initially.
My turnbuckles are frozen (rust). They're soaking in penetrating oil now, but I may have to use a fire wrench.
Before I do this, I wanted to find out was typical sway was...from the most trustworthy source...our bretheren on TBN!
Well, I did find part of my sway problem.
Went to a Deere dealer. Although they were closed, there were several 4100 tractors on the field. A perusal of the 4100N online manual (and my 670 manual...not a real clear picture in my manual though) indicated something was missing. Hence, the trip to the Dealer.
There are two spacers (~ 1.00" in length) that should be on the shafts that the lower links (tractor end of the link(s)) mount on. The anti-sway turnbuckets mount on the same shaft.
Since both are missing, they must have been purposely removed at some point in time.
Without the spacers, the tractor end of the links can move laterally about an inch. No wonder I'm getting excessive sway on the mower!
Reckon they weren't there when I bought the machine. I just didn't know any better then...
Y'see how TractorByNet educates ya!!!
BTW, there was a 955 tractor on the same lot. This has a very similar arrangement (at the lower links) as my 670 does. As mentioned, the 4100 tractor also shares the setup. It's quite possible most of the x70, x50 and x55 series Deeres also share this setup. The 4200 series and larger are different (I looked at most of them).
So, another trip to the Deere dealer to obtain these spacers.
As they are simply 1/16th (1.5 mm) thick cadmium plated tube stock...about an inch long (probably 25.0 mm since it's a Yanmar built machine), they can't be too expensive...
Of course it's Deere, so they're probably $79.85 each.
2016 Cadillac XTS Sedan (A61569)
2016 Cadillac XTS...
Triple Sink Table (A60352)
Triple Sink Table...
2014 HEIL CRUDE TRAILER (A60736)
2014 HEIL CRUDE...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2015 Peterbilt 567...
2013 Ford Escape AWD SUV (A61569)
2013 Ford Escape...
2003 FREIGHTLINER FL70 DAY CAB (A60736)
2003 FREIGHTLINER...
