Late Model Brush Cutters
   / Late Model Brush Cutters #1
SnowRidge
Elite Member
East Tennessee
Power Trac PT-425 / Branson 3520
At some point, Power Trac made a significant change to the brush cutter for the PT-4XX series. The older model has the motor mounted up high with an obvious Lovejoy coupler above the deck. The new model, which I have, has the motor sitting right on the deck.
We have info from Moss Road on what he found when he took his old style cutter apart, but as far as I know, there hasn't been anything on the new style's internals. Has anyone taken the new style's drum assembly apart? Are they still using an automotive hub under there? I would love to know before I have to tear into mine. :)
   / Late Model Brush Cutters #2
I'd like to see a shot of the motor area a little closer and from the front.
I'll snap one a post it later today, if someone doesn't beat me to it.
I guess it is later. :) Three views attached.
   / Late Model Brush Cutters #5
Mine is about a year old, but it looks a little different. The motor looks "taller" in my pic.
The quick attach is different, too. Yours looks lighter, and it is bolted instead of being welded.
Which model PT is that, 418 or 422?
   / Late Model Brush Cutters #7
It's a 422 bought a little over a year ago.
   / Late Model Brush Cutters #8
Notice how it has those two straps bolted on? They look like guides so that the unit can tilt side to side, but not flex the pivot joint fore and aft too much.
   / Late Model Brush Cutters #10
It would seem that they are trying out new things, which means that they are not satisfied, or their supplier let them down. It seems like I have one of a kind PT-1445. My Tram pump is an Eaton, and the PTO pump is a Cessna, and the steering/lift pump is a Haldex. I believe that I have the only 1445 with a 4 cyl gas engine, with a radiator system. There may be some out there, but not logged on the web site.
1987 FORD 2110 TRACTOR (A51222)
1987 FORD 2110...
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2015 Ford F-250...
2015 PETERBILT CLASS 8 CEMENT MIXER TRUCK (A51243)
2015 PETERBILT...
2021 CATERPILLAR 953 CRAWLER LOADER (A51242)
2021 CATERPILLAR...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2017 Caterpillar 259D Two Speed Compact Track Loader Skid Steer (A50322)
2017 Caterpillar...
