Complete Turf Care
- Joined
- Mar 31, 2013
- Messages
- 1,998
- Location
- South Louisiana
- Tractor
- 2022 Kubota Grand L6060 (no loader), 2017 Kubota Grand L6060, 2011 Kubota L5740 HSTC-3, 1997 Kubota M4700
Voltage or hyd pressure.
There should be o-rings around the solenoid shaft going into the valve. They should be sufficient if there is no hyd spike.
The proportional valve works in relation to the signal it receives, could be large or small increments.
Is there a sensitivity adjustment on the valve or in the laser system.
There are adjustments on the laser system. One is for reaction time. I can increase or decrease the amount of time it will take to allow the system to change the blade height.
The other adjustment is to increase or decrease the 'dead zone' on the receiver. This will cause the blade to change height when it is more than the 'dead zone' off grade. I can set this to adjust the blade height at as little as 1/8" or as much as 2".
These adjustments are to avoid excessive movement of the blade (causing excessive heat). I will decrease the 'dead zone', and reduce the reaction time, as I get closer to finished grade.
However, I don't think either of these adjustments have anything to do with my 'coil' failure.
