Complete Turf Care
- Joined
- Mar 31, 2013
- Messages
- 2,165
- Location
- South Louisiana
- Tractor
- 2022 Kubota Grand L6060 (no loader), 2017 Kubota Grand L6060, 2011 Kubota L5740 HSTC-3, 1997 Kubota M4700
I have a laser grading system on an 8' blade that I use to grade athletic fields. As long as I had it on the New Holland TC45 in the pics, it worked fine. But, I bought a Kubota L5740 and on the first grading job with the Kubota, the valve shown in the pics failed. And, that valve cost about $800.
I was told that the reason it failed was because I had hooked up my hoses backwards and applied pressure in the wrong direction. I replaced the valve and went on to the next job. It seemed to work fine, but after about 8 hours of working, I'm starting to notice some oil coming from the $800 valve again. I'm not sure it will fail again, but I know that I can't afford to replace that valve every 10 hours or so.
Does anyone have any suggestions on what may have caused it to fail, and what could I do to prevent another failure? I do know that I did hook the hoses wrong on the first valve, but only applied pressure for a few seconds. I don't think I hooked them wrong for the second valve at all.
Could it have anything to do with the different tractor?
And, someone told me that I needed to add an inline 'backflow preventer' to prevent reverse pressure being applied to the valve.
