Largest JD Tractor With Autoconnect Deck
/ Largest JD Tractor With Autoconnect Deck #1
dieselscout80
Elite Member
South Carolina
New Holland TC45DA
What is the largest JD tractor that uses the Autoconnect Deck?
Is there anything larger than the 3720 in the pre-emission tractors?
I’d like to have a little over 40 PTO HP as a minimum?
So is the 3720 the largest JD that has the auto connect deck?
/ Largest JD Tractor With Autoconnect Deck #3
Which model did your John Deere dealer say was the largest one???
SR
I’m looking for used tractors not new.
The 3720 is the largest I have found, so far.
/ Largest JD Tractor With Autoconnect Deck #5
I'm not sure it is offered on anything above the 3 Series but a dealer would know for sure. You probably aren't getting many responses because most people that move above the 2 Series are mowing many acres of grass with a larger tractor and they use a large 3ph mower. They then use something smaller to mow the grass right around the house. The 3ph mowers tend to be less than the autoconnect MMM and are larger. I mean for the price of the 72" autoconnect deck you can get a pretty good z-turn for mowing right up next to the house and around obstacles. Just something to think about....
/ Largest JD Tractor With Autoconnect Deck #7
From what I can find, the 3720 is the largest pre-emission unit that is compatible with the 72D deck.
It looks like anything bigger than the 3720 (pre or post-emission) will require a rotary cutter out back on the three point.
/ Largest JD Tractor With Autoconnect Deck #8
Auto connect was released in 2008 (I believe), the 3x20 series was the largest tractor to accept a auto connect deck. 4x20's could still take decks, just not auto connect.
/ Largest JD Tractor With Autoconnect Deck #10
That would make for a rider on steroids!
/ Largest JD Tractor With Autoconnect Deck #11
For sure!
Would make my x584 with the 54-in. Accel deck look puny. :)
I can see that a 72D mid-mount mower deck would be useful on a large pasture with lots of trees or serpentine edges that needed close-in cutting.
2012 STEPHENS CRUDE PUP TRAILER (A67714)
2012 STEPHENS...
2018 JOHN DEERE 350G LC EXCAVATOR (A65056)
2018 JOHN DEERE...
2019 DRAGON ESP 150BBL ALUMINUM (A67714)
2019 DRAGON ESP...
1991 26ft Pursuit 2350 Walking Around Cabin Cruiser with 2017 21ft S/A HMDE Performance Boat Trai... (A66738)
1991 26ft Pursuit...
2014 FREIGHTLINER CASCADIA (A67714)
2014 FREIGHTLINER...
PALLET OF HYD HOSES (A68842)
PALLET OF HYD...
