Largest JD Tractor With Autoconnect Deck
/ Largest JD Tractor With Autoconnect Deck #1
dieselscout80
Elite Member
South Carolina
New Holland TC45DA
What is the largest JD tractor that uses the Autoconnect Deck?
Is there anything larger than the 3720 in the pre-emission tractors?
I’d like to have a little over 40 PTO HP as a minimum?
So is the 3720 the largest JD that has the auto connect deck?
/ Largest JD Tractor With Autoconnect Deck #3
Which model did your John Deere dealer say was the largest one???
SR
I’m looking for used tractors not new.
The 3720 is the largest I have found, so far.
/ Largest JD Tractor With Autoconnect Deck #5
I'm not sure it is offered on anything above the 3 Series but a dealer would know for sure. You probably aren't getting many responses because most people that move above the 2 Series are mowing many acres of grass with a larger tractor and they use a large 3ph mower. They then use something smaller to mow the grass right around the house. The 3ph mowers tend to be less than the autoconnect MMM and are larger. I mean for the price of the 72" autoconnect deck you can get a pretty good z-turn for mowing right up next to the house and around obstacles. Just something to think about....
/ Largest JD Tractor With Autoconnect Deck #7
From what I can find, the 3720 is the largest pre-emission unit that is compatible with the 72D deck.
It looks like anything bigger than the 3720 (pre or post-emission) will require a rotary cutter out back on the three point.
/ Largest JD Tractor With Autoconnect Deck #8
Auto connect was released in 2008 (I believe), the 3x20 series was the largest tractor to accept a auto connect deck. 4x20's could still take decks, just not auto connect.
/ Largest JD Tractor With Autoconnect Deck #10
That would make for a rider on steroids!
/ Largest JD Tractor With Autoconnect Deck #11
For sure!
Would make my x584 with the 54-in. Accel deck look puny. :)
I can see that a 72D mid-mount mower deck would be useful on a large pasture with lots of trees or serpentine edges that needed close-in cutting.
NEW HOLLAND 110TL LOADER ATTACHMENT (A67714)
NEW HOLLAND 110TL...
2014 RETESA 210BBL CRUDE TRAILER W/ PUMP (A67714)
2014 RETESA 210BBL...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
7ft Fork Extensions (A66734)
7ft Fork...
CLUB CAR  CARRYALL 6 (A67714)
CLUB CAR CARRYALL...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
