larger front rim
/ larger front rim #1
Alan O
jackson nj
new holland tz24da
I have a 2005 nh tz24da. The front rim is 8.inch. can I put a 10 inch rim on it without causing damage? I can't find r4 in 8 inch .thanks for any info
/ larger front rim #2
The width of the tire is of no concern as long as there is proper clearance. You have to measure the outside dimension. It has to be really close to the one you are replacing or the ratio of front /rear drive is going to be off.
I would pull a string around the 8" tire and compare the length to the 10". If it is within an inch or two I think you would be ok. The ratio is designed so that the front tires run a little faster than the rear so they are always pulling forward a bit on the rear which is one of the reasons why the fronts wear faster than the rears.
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
1999 John Deere 345 Lawn Mower (A63116)
1999 John Deere...
Kholer Magnum 10 Compressor (A63118)
Kholer Magnum 10...
1997 Freightliner FL70 Rollback Truck (A63116)
1997 Freightliner...
UNUSED KJ 12'X20' SINGLE GARAGE METAL SHED (A62131)
UNUSED KJ 12'X20'...
