larger front rim
/ larger front rim #1
Alan O
jackson nj
new holland tz24da
I have a 2005 nh tz24da. The front rim is 8.inch. can I put a 10 inch rim on it without causing damage? I can't find r4 in 8 inch .thanks for any info
/ larger front rim #2
The width of the tire is of no concern as long as there is proper clearance. You have to measure the outside dimension. It has to be really close to the one you are replacing or the ratio of front /rear drive is going to be off.
I would pull a string around the 8" tire and compare the length to the 10". If it is within an inch or two I think you would be ok. The ratio is designed so that the front tires run a little faster than the rear so they are always pulling forward a bit on the rear which is one of the reasons why the fronts wear faster than the rears.
(4) Tex Star 205/75D/15 Tires and Rims (A64047)
(4) Tex Star...
429133 (A61165)
429133 (A61165)
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
2004 Mack CL713 Tri-Axle Heavy Haul Truck, VIN # 1M1AD64Y04M001417 (A61165)
2004 Mack CL713...
UNUSED JCT 72" HYD TILLER (A62131)
