Larger CCA battery
/ Larger CCA battery #21
I use one on my garden tractor during the winter and my brother uses one on his JD 4020 to keep the float voltage topped off haven't had any problems with either one of them. They seem to work ok even when they get wet.
/ Larger CCA battery #22
oliver28472 said:
On the wife's VW, the battery will go down within 2 days if it don't get some help. We were gone earlier this month for 10 days. I left the solar charger place in the sunroof and plugged in. Started right up when we got home. This charger will not overcharge the battery and it came with the car. I know we shouldn't have to use it but the sad truth is the dealer couldn't find anything wrong with the car even though it died on their lot.
My wife has a 03 jetta and one of those solar panel came with it. Gets a lot of use in the garage :) Just a jab in the dark, did they check the trunk light switch? This will drain a weaker battery over time if the light is stays on. If they were worth their salt they should have run an amp meter and start pulling fuses to see what circuit is causing the most drain. Did you ever try a new battery??? There really is no reason why you should be carrying that charger around in a new car..
VT
/ Larger CCA battery #23
Higher CCA usually means shorter battery life. Higher CCA is obtained with more plates in the battery, more plates means more heat which means shorter life.
/ Larger CCA battery #24
What about batteries that don't use plates?
/ Larger CCA battery #25
I use a battery tender, mine was about $18 at WalMart. Seems to work well on my MF1010. I also rigged up a 250w heat lamp to sit on the concrete in the garage under the oil pan. You can get a lamp at most big box pet stores; they're commonly used for reptile cages. The bulbs there are expensive though. Got mine at Ace Hardware instead. Brings the oil temp up nicely after an hour. That will help with both oil pressure and cranking speed.
/ Larger CCA battery #26
one thing to watch out for when going with higher CCA batteries, and *especially* if you run a deep cycle battery, is what it does to your alternator and voltage regulator.
A large battery, slightly discharged, can easily try pulling 60+ amps from your charging system, pretty much all these tractors are not up to the task with the puny 15 amp alternators. This can kill a voltage regulator quickly, trying to support that much amperage draw after the engine starts.
-scott
/ Larger CCA battery #27
-scott
Won't the alternator just current limit to 15 amps and protect itself? The voltage will drop and the current will drop. An alternator can be overloaded by many things and then the battery starts discharging. At least that's my understanding. If it did not protect itself, then charging a fully discharged battery might damage the alternator as a lot of current would be required during the initial charging.
/ Larger CCA battery #28
[Autozone's] Dual Purpose Marine group 27 is only $59.
[The clerk] said this is what they use on harvesters etc that are parked for months, because a marine battery has less self-discharge than an automotive battery.
It's 1000 Marine Amps, comparable to 1000 automotive Cranking Amps (both @ 32 degrees) which corresponds to about 850 CCA (zero degree cranking amps).
Yanmar specifies 75 amp-hours, this is 115 amp hours.
One year followup:
Works great. It's never had a charger on it since I installed it one year ago. Highly recommended!
/ Larger CCA battery #29
-scott
I tend to disagree, The fact is, that the battery will only get what the regulator tells the alternator is available. If the tractor has a 15 amp charging system, then the output to the battery should be 15 amps at low battery condition. As the battery comes up to full charge, the current is regulated down to a trickle. This cycle will repeat itself if all things are normal. A dead or weak battery has low voltage, and the regulator reads this and regulates the current to the battery. A bad regulator will try and over charge the battery, or not charge at all.
/ Larger CCA battery #30
Bob,
I know this is an old post, but.
Since the beginning of the car, battery, and charging system relationship, , we have been charging dead battery's. The only problem trying to start a car with a dead or weak battery, is that there is not enough energy left in the battery to turn the starter. If you jump the battery, and it starts, then the regulator system takes over and charges the battery at the max rate until charged.
/ Larger CCA battery #31
This is an old thread. Reading all the post what I see is a lack of understanding of how lead acid batteries are charged and the charging system found on our Yanmars.
LA batteries are charged via constant potential (voltage). In electrical terms, voltage is pressure. If the charge source is fixed, the charge rate varies with the voltage difference between the source and the battery. As the battery voltage rises due to charging, the lower the voltage difference so the lower the charge rate. When source and battery voltage equal the will be no charging taking place. Think of charging like siphoning water between 2 buckets, one full the other empty. The rate of transfer between the full and empty buckets is greatest to begin with and declines as the water levels near each other and flow stops when they are the same.
Now for our Yanmar charging systems. From the schematics I've seen, all have only 2 wires that connect between the alt and the "voltage regulator". Notice, there is no direct connection betwen the alt and battery. With this system no real regulation of the voltage can be made by the alt. The function of the VR is to rectify the AC voltage to DC. It regulates the voltage down stream by shunting some of the power to ground until the set regulated voltage is reached. From a practical standpoint this is the reason why these alt are so small power wise. They function the same way you find in small engines we find in lawn/garden tractors.
LA batteries when in normal condition have very small self discharge rates, ~.1%/day of remaining capacity. On my garden tractors they sit for about 5 months over winter and they never see a charger. At most, they see a few mins from a charger while I check fuel & oil levels before starting the first time in the spring. They always have adequate power to start the equipment and the batteries last at least 5 yrs. The Yanmar sees some use over the winter months but never sees a charger and never a problem. If you can't keep your battery charged over the winter without it being discharged when time comes to put the equipment back in use, you likely have some problem(s) that need addressing.
/ Larger CCA battery #32
Mickey FX,
If you were referring to me, I believe that I have a good understanding of how alternators work in tractors, cars, and small engines. What part do you think that I don't understand? I have quite a few years working on generators, alternators, batteries and regulators. There is not a whole lot to understand. They are simple in design. For the most part, if they don't work, you simply replace them. Trouble shooting is the key to solving problems with todays electronics or electrical products.
On most any regulator, you have A/C going to the regulator, and there are 4 connections, one ground, two A/C wires, and one wire for DC battery voltage. The A/C voltage is rectified and sent out to the battery The field current and speed of the alternator determine the current and voltage. You generally always need more voltage than the source you are trying to charge. You can have 14.2v up to 15v and still be safe. There will be voltage drops throughout the machine as you trouble shoot different components.
/ Larger CCA battery #33
It is my understanding that an alternator was designed to deliver constant voltage regardless of rpm/speed, unlike a generator. Hence the lights don't dim at an idle.
/ Larger CCA battery #34
Sounds like a zener diode limiting voltage by wasting current. I guess Yanmars must also be unusual in the respect of rectification happening in the "voltage regulator". For many years the rectification has been done conventionaly by six diodes in the alternator. The regulator just samples batt V and energizes the alt field rotor appropriately so that a correct amount of power is induced in the stator and fed thru the 3phase rectifier to bring the battery to nominal V, and then tapers field current to maintain it there.
larry
/ Larger CCA battery #35
No, if that were true, the voltage would be constant at all times.
The regulator will attempt to maintain a pre-determined charging system voltage level.
When charging system voltage falls below this point, the regulator will increase the field current, thus strengthening the magnetic field, which results in an increase of alternator output.
When charging system voltage raises above this point, the regulator will decrease field current , thus weakening the magnetic field, and results in a decrease of alternator output.
/ Larger CCA battery #36
My previous comment wasn't directed to any specific person, just an observation noted from reading all the posts.
JJ, not sure what you mean by "most any regulator". Are you talking about Yanmar and sim systems or that generally associated with automotive charge systems? If the later, I have to agree with SPYDERLR's comments. One comment you made if you are talking about the Yanmar system is, there is no field winding. I also disagree with your comment about being OK to have voltages up to 15V. That's way above the point where a nom 12v LA battery would be happy. A typ automotive charge system doesn't go much beyond 14.25V. Any charge voltage above ~13.9 can be an issue. Voltage and duration will determine what happens. Can be as little as overcharging, i.e. boiling of the electrolyte, to shortened life.
You gave some of your background so I've give mine. A retired Eng from HP. In the mid-80's I did some research on LA batteries for use in portable medical equipment. Based on that work our equip moved from Ni-Cads to LA and the whole industry followed within a few yrs. Not claiming to be an expert but I', more than familiar with care and feeding of LA batteries and typ charge systems.
/ Larger CCA battery #37
If the Yanmar alternator does not have a field winding, what does it have to induce a field.
Even if the regulator is separate from the alternator, the grounding of the alternator and regulator is one of the paths for voltage and current.
This statement has to do with battery chargers.
Many modern chargers are charging wet cell batteries at much higher voltages than previously. 14.8 to 15 volts is becoming common. This increases the charge rate and performs a mild equalization charge. It is not recommended that such a charge voltage be used from an alternator as the alternator does not have the ability to drop to a lower float charge the same way that a dedicated charger does.
Another observation that I have made with Ni-Cad batteries is that on an 18v DeWalt charger, I have measure the charge voltage at 24 v. A 12V charger will charge at 15-16 v.
I really see no problem with charging at a higher voltage, because if the system is well regulated at say 14.2v, it may start out at 15v, and as the charge builds up to the regulated voltage, the amount of charge tapers off.
How many of you have used the 125 amp mode on some of those large chargers to get a fast charge on a battery.
Yes, I agree that if left on for a while, the water will boil out, or the sides will bulge and maybe explode.
Do you have a schematic of a Yanmar charger system?
If the alternator goes out on my Kubota, I think I would replace it with a small one wire Ford alternator. Way cheaper and will allow more acessories.
/ Larger CCA battery #38
Probably permanent magnets.
I find that wet cell lead-acid will charge to around 14.7+ at a fast charge rate, but if you then reduce the charge rate to about 1/4A they will continue on up to 15.2+ over a 2day period because they develop a surface charge over and above the deep charge. Most of the newer automotive systems charge the battery pretty fast up into the mid 14s then slack off slowly to high 13s for a float - like on a long trip. The regulator controls the alt to achieve this.
Youre probably seeing the full wave rectified peak on those chargers. There may be a capacitor holding the peak and giving you the measurement even with a true RMS meter. A battery will do this to an [lesser] extent also.
Regulator is built into the 1 wire alts.
larry
/ Larger CCA battery #39
Keep in mind Yanmar used several types of charging systems. One of the best known, on YM2000, was a conventional Hitachi alternator and regulator same as what Hitachi provided to Datsun for automotive use.
/ Larger CCA battery #40
Bob,
I think we are saying about the same thing with just some different wording. I agree with all of your comments in this thread. Charging systems and batteries can be complex. Particularly batteries. Any time you talk about batteries it is difficult to be totally correct since there are so many variables. Most car charger systems start with a higher voltage and then drop to a lower voltage once the system is warmed up.
Wooden Glider Chair (A64557)
Wooden Glider...
2025 Wolverine BC-13-72W 72in Brush Cutter Skid Steer Attachment (A64553)
2025 Wolverine...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
JOHN DEERE 8' HYD BLADE, 3PT (A64278)
JOHN DEERE 8' HYD...
2020 CATERPILLAR 279D3 SKID STEER (A65053)
2020 CATERPILLAR...
2002 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2002 Ford F-250...
