Tiller Large rototiller
   / Large rototiller #11
This one I am getting is 93 inches for tilling width, so my tractor (4720)will get a workout no doubt, but I do have a hydro.
In my view, a hydro is a detracting feature not an enhancement. Hydro's consume power that gear drives don't.
   / Large rototiller #12
Just curious what you'll be doing with that big a tiller. Around here, those big ones seem to be used more for specialized applications. And I'd agree that will give your machine a workout. Depending on soil conditions, I've found working the ground in 2 passes (first pass at a shallower depth), does the best job. That might help in your situation also.
   / Large rototiller #13
Two passes will help but I think your really looking at too much tiller for your tractor. John Deere has 70 HP as the minimum to run the 1207 and your tractor has 56 pto out of a smaller displacement engine. Also the tiller weighs in at 1500 pounds and your lift @24 inches is 2500. Have you looked at the RT 1280? It is for tractors as low as 40 HP and still tills 83 inches wide. That being said I think your tractor will be able to work the 1207 but its going to be really taxed doing it. I would love to hear about how it works out for you. I have 44 PTO tractor and have wondered about getting a wider tiller for it. I'm looking at a Kuhn that is 82 inches wide.
   / Large rototiller
My old rototiller is in Jamestown, North Dakota. My old 6 foot rototiller did not even phase my tractor (even when operating in the economy PTO mode) so I feel I will be just fine working at the four inch or so depth with the extra two feet of width. If I drop it in to max depth then I am guessing I would be short of HP, then I would have to swipe my brothers tractor from him.
   / Large rototiller #15
I use the Deere 673 behind my 4520 in economy pto at full depth without issues in sandy loam soil. Using the standard pto setting no issues in any soil so far. With 50 pto hp I should have gone with the 681 tiller (80 inch).
Tritonman,
If you are tilling less than six inches deep you shouldn't have any problems using the standard pto and would guess about 1.5 mph.
   / Large rototiller #16
You will make better time with a smaller unit that's better suited for your tractor.
   / Large rototiller #17
I would have said that 93" is too big for your tractor, until this year. I bought a 84" King Kutter for my DX55 and it runs as smooth as silk. I have no doubt I could handle an 8' model if I wanted to. I think the key will be the type of soil. If you plan to use it in sod a lot, then a smaller one might be better. I know I was pleasantly surprised at how low RPM I could run mine, even in the hardest soils.
   / Large rototiller
I will pick it up at the end of this week. I can't wait to get it and to go try to work up some sod and plant a late food plot of oats and peas.
   / Large rototiller #19
Exciting isn't it? Keep up informed on how it does for you. I'm thinking of gettting a bigger one for my 44 PTO tractor but not as big as yours! Good luck and looking foward to a full report.:thumbsup:
   / Large rototiller
I got the tiller home yesterday. Worked great down to about four inches at 1.7 to 2 mph. Breaks sod at 1.1 mph at 6 inches. Extremely happy. Nice to have a tiller that doesnt hop around on the hard ground. The tractor handles the 1500 lbs just fine. Will post some pics later
Air Chipping Hammers (A55851)
Air Chipping...
2014 Cummins ISL 320HP 8.9L 6-Cylinder Turbo Diesel Engine (A55852)
2014 Cummins ISL...
2014 10ft T/A Dump Trailer (A51691)
2014 10ft T/A Dump...
2007 Ford F-150 Ext Cab Pick-up Truck (A53422)
2007 Ford F-150...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2019 Nissan NV200 Cargo Van (A55852)
2019 Nissan NV200...
