Tiller Large rototiller
   / Large rototiller #1
Tritonman
Gold Member
What are you guys running for a large rototiiller. I am dealing on a frontier 1207 93 inch model and am looking for feedback
   / Large rototiller
I have a 6 foot buhler for sale now 2000 bucks
   / Large rototiller #4
When we grew potatoes we had 100inch Howards and Krones ...Howard were stronger / Krone did a better job but rusted badly to the point where the lids would need replacing and rust holes right through ...mechanically no real difference.
   / Large rototiller #5
I'm going on my third year with my Frontier 72" tiller. It has been absolutely trouble free. I only wish the ujoints were easier to grease as the pto shaft shield is TIGHT and hasn't seemed to loosen up any.
The paint is a little on the tender side, but I simply rattle can it with jd green when spots arise.
   / Large rototiller #6
Define "large", please.
I've been running a 72" Muratori for a number of years now, and it has been fine. Usual issues with lubing the pto shaft u joints, and it jumps quite a bit when you hit a large rock, but does a great job of churning up the soil. That said, it's really too large for our use, and I'm looking at a 48" tiller to use with the small tractor.
The 6-7 foot tillers are about the largest I've seen in a Cat I hitch configuration. Any 35-50 hp tractor should run them without problems.
The dealer also had some really large tillers... 8-12 ft. Cat II, much heavier and probably 75-100 hp needed to run them... used in production ag applications, not for gardens and food plots.
   / Large rototiller #7
The shaft shields will loosen up or disintegret from the sunshine. I have to disenguage the tiller end from the shaft to grease that end. I am going to remedy that this winter.Its not large, just 58 inches dig..
   / Large rototiller #8
About 3/4hp- 1hp per inch is normal depending on conditions
   / Large rototiller
This one I am getting is 93 inches for tilling width, so my tractor (4720)will get a workout no doubt, but I do have a hydro.
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2012 International...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A54814)
2021 International...
2008 Dodge Ram 1500 (A55973)
2008 Dodge Ram...
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
2013 John Deere 35D Mini Excavator (A55973)
2013 John Deere...
2016 Ford F-150 4x4 Pickup Truck (A54814)
2016 Ford F-150...
