Tiller Large rototiller
   / Large rototiller #1
Tritonman
What are you guys running for a large rototiiller. I am dealing on a frontier 1207 93 inch model and am looking for feedback
   / Large rototiller
I have a 6 foot buhler for sale now 2000 bucks
   / Large rototiller #4
When we grew potatoes we had 100inch Howards and Krones ...Howard were stronger / Krone did a better job but rusted badly to the point where the lids would need replacing and rust holes right through ...mechanically no real difference.
   / Large rototiller #5
I'm going on my third year with my Frontier 72" tiller. It has been absolutely trouble free. I only wish the ujoints were easier to grease as the pto shaft shield is TIGHT and hasn't seemed to loosen up any.
The paint is a little on the tender side, but I simply rattle can it with jd green when spots arise.
   / Large rototiller #6
Define "large", please.
I've been running a 72" Muratori for a number of years now, and it has been fine. Usual issues with lubing the pto shaft u joints, and it jumps quite a bit when you hit a large rock, but does a great job of churning up the soil. That said, it's really too large for our use, and I'm looking at a 48" tiller to use with the small tractor.
The 6-7 foot tillers are about the largest I've seen in a Cat I hitch configuration. Any 35-50 hp tractor should run them without problems.
The dealer also had some really large tillers... 8-12 ft. Cat II, much heavier and probably 75-100 hp needed to run them... used in production ag applications, not for gardens and food plots.
   / Large rototiller #7
The shaft shields will loosen up or disintegret from the sunshine. I have to disenguage the tiller end from the shaft to grease that end. I am going to remedy that this winter.Its not large, just 58 inches dig..
   / Large rototiller #8
About 3/4hp- 1hp per inch is normal depending on conditions
   / Large rototiller
This one I am getting is 93 inches for tilling width, so my tractor (4720)will get a workout no doubt, but I do have a hydro.
2007 Saturn Sky Convertible Coupe (A55853)
2007 Saturn Sky...
2016 Ram 5500 Enclosed Service Truck (A52377)
2016 Ram 5500...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A57024)
Neckover GL24-2-7K...
2017 Ford F-350 (A56858)
2017 Ford F-350...
UNUSED FUTURE SF60 60" HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
2015 INTERNATIONAL FLATBED (A58214)
2015 INTERNATIONAL...
