landscape rake
/ landscape rake #1
Nat
Platinum Member
Central NC
Eddie started a thread on making a simplified landscape rake a few weeks ago. I asked him where to get the tines and ordered some for myself. I used steel that was already here so I didn't have to go buy any more. I made the main frame out of some 1" X 2" X 1/4" tubing. The triangle shape is so It will have lateral strength. Here is a pic of the frame started.
/ landscape rake
I was at Northern Tool a while ago and bought a swivel for a trailer jack, but instead I repaired the one that was on it. This swivel was here and doing me no good so I put it to use. It is a piece of DOM tube 3" ID and a piece of 2 3/8" OD that was 3/8" longer than the outside piece. I welded the shorter,larger piece to the ends of the 1" X 2" tubing. I welded a piece of the same sixe tubing 24" long to form the other end of the frame triangle which made it 25" wide. A piece of 2" X 1/2" flatbar bent to a slight angle covered the joint and made the place to mount the 3PH pins.
/ landscape rake
I have a drill press so drilling the holes wasn't as big a job as Eddie is doing. I wasn't sure if I wanted the tines at 2" centers or 3" centers so I drilled every 1" on center.
/ landscape rake
After drilling the holes I decided to go with the 2" on center tine spacing and it seemed to work pretty well.
I welded a piece of 8" X 8" x 3/8" plate to the inside piece of tubing and 2 pieces of 1/2" X 2" between the frame rails and drilled a 3/8 hole thru for the start of my swivel lock. After this I turned it upside down and drilled up from the bottom for the angle holes on each side of straight and then turned it backwards and drilled one straight for there. I turned it back over and took a 3/4" reamer in my big 1/2" drill and opened the holes to 3/4" That way the holes stay aligned, which is something I have had trouble with in the past.
/ landscape rake
Here is the finished rake. I used it to rake the drive, spread a load of mulch, and rake the area in front of the new tractor shed and I'm very happy with the results. Later, Nat
/ landscape rake #6
Hey Nat,
Nice job with the rake. Did you buy the same tines that I did? They are the largest one they sell and cost almost $5 each. Do they flex at all? They sure seem to be extremly stiff.
I'm putting mine at 3 inch centers and wonder how yours did at 2 inch centers. Did you pick up very much dirt??
I have my tines 7 feet back from my tractor so I can hold more material and reach in and around the trees better. Did you find that your rake filled up with branches quickly? I'm wondering if I've made mine so long that it will become awkward and back heavy.
Have you changed the angle of your rake? Did it do anything?
The block of wood in your last picture looks like it might be a nice feature to have welded on. Do you think a pipe slid inside another pipe and a pin would work good for a retractable stand?
I'd sure like to see some pics of it in action. Maybe a before and after shot along with how well it holds material.
Thanks,
Eddie
/ landscape rake
Eddie, the one I got were 3.99 each. They have 2 each 3/8" holes 1 1/2" apart. They are pretty stiff but seem to work fine. I am using it to windrow rocks and it works good for that at the 2" spacing, and doesn't seem to pull much dirt along, but I think for branches and limbs 3" spacing may be better, cause weeds and grass will build up pretty fast.
Set on an angle it seems to windrow the rocks pretty well, but willdump them as you turn if you don't watch pretty close. I thought about a pipe jack for the front, but it weighs very little so I will just pick it up for the time being.
I'll try to get some action shots in the next day or so. I'm really impressed with how the ground looks after a pass thru, so I expect it to do a good job. Vickie wants me to sow an area below the house so she can watch the deer feeding. I figure I'll need to mow the area first so that it doesn't drag up to many weeds. I will plant it in Rye for the fall and maybe mix in some fescue so that when winter is over they can feed on fescue. BTW, I have a great big old comercial drill press you can have, just be a long way to come pick it up.
Does any TBN folks need an old drill press, it's a whopper, an Excelsior #20. I bet it weighs 900 lbs and is in good shape except it needs a 3/4 HP motor. let me know, all you have to do is come and get it. Later, Nat
/ landscape rake #8
Ditto on the action shots. This is a tool I'd like to make - right.
I'v seen a lot of ideas on TBN but not as many pictures of sucess. Makes me wonder if others (besides me) also have ideas that don't work as well as imagined. One of the best things we can share is our failures so others don't duplicate the failure.
One thing would question is - how much twist do you see in the support bar for the tines?
/ landscape rake #10
One source, where I got mine, is Agri-Supply. They sell the same tines that are used by Woods and Landpride. I went with the standard duty 2-hole tines. Page 48 of the September 2006 catalog. part # 33913 for $2.99 each. Warning, if you order any large quantity of tines, break the shipment into two orders so you do not have to pay the overweight shipping charges.
Agri-Supply Catalog page 48
/ landscape rake
The ones Mad told you about are the same as the ones I bought. I looked at the agri supply website and asked about them. They gave me the price and what shipping was. in my case 23.00. They got here in 3 days. They were in 3 different boxes so they could come UPS. Later, Nat
/ landscape rake
I had a chance to use it some yesterday afternoon and can report it works very well. I can back up into the edge of the tree line lower the lift and pull forwqrd and it will pull out the limbs laying on the ground and a lot out the small growth also. I have an old terrace below the house where I'm putting the debris so I just pull several rakes full to the edge of the terrace and every 4th or 5 th time I just push it off the bank. It rakes up the rock pretty well. I have a lot of golf ball to baseball sized rock on the surface from when we put the septic tank and lines in and it picks them right up. Some will fall off the ends but I just moved over a little for the next pass and it gets them then. One little problem is the tines spring some and if you hit a rock that is burried and it doesn't come up sometimes it will skip over it and the tines springing back will through a smaller rock at you. They can sting the back of my little legs pretty good. I have an old C-Farmall and the seat is exposed from the back so it shouldn't be much problem for a CUT as they are more protected. I didn't stop till dark and was going to take some pics this morning, but it is raining like a cow peeing on a flat rock, so I worked in the shop today. I have another project tractor, a B Allis Chalmbers. It is a nice old tractor and I am going to paint it and put a 3PH on it. It will get around in tight places better than the C. Later, Nat.
BTW any takers on my drill press? The price is right"FREE" can't find one any cheaper. Nat
/ landscape rake #13
Nat,
Thanks for the report. I'll start planning for my landscape rake project. It sounds really useful.
Jim
/ landscape rake #15
Nat, nice job on the rake. Now design a skirt to protect yourself and tractor from the flying rocks. I use my rake to remove snow on a slag road and am always getting hit with pieces of slag. I'm going to try and design something before winter gets here.
/ landscape rake #16
Nat said:
.....BTW any takers on my drill press? The price is right"FREE" can't find one any cheaper. Nat
If it wasn't so far away and if I had a place to put it I would gladly take it. :(
2019 ISUZU NPR 16FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 ISUZU NPR...
2004 BMW 325ci Convertible Coupe (A62613)
2004 BMW 325ci...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
2021 KUBOTA RTV-XG850 SIDEKICK RTV (A64277)
2021 KUBOTA...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
MCCORMICK FARMALL SUPER A TRACTOR (A64277)
MCCORMICK FARMALL...
