Landscape rake power angle question
/ Landscape rake power angle question #1
Junkman
Super Member
North East CT
2003 Kubota BX-22
I want to install a power angle cylinder on my landscape rake. Any suggestions as to size of cylinder are appreciated. Also any pit falls to avoid? How do you measure to find the best cylinder for the application. The tractor is a Kubota BX22 with a 1800 PSI / 5 GPM pump output. Thanks...
/ Landscape rake power angle question #2
I would guess that a 2" or 3" bore 2500 psi double acting cylinder with a rod diameter of 1.125" to 1.5" would be adequate. These typically have 3/8 NPT ports. If you rake is lightweight the 2" would be just fine.
A welded cylinder is probably overkill so I would go with the inexpensive Chief cylinder from Surplus Center. A cylinder with a 6" stroke will set you back less than $60 without shipping.
/ Landscape rake power angle question #3
junkman,
madreferee has it right and the new tsc store in enfield has all the items you will need and no i have no interest in tsc. glenn also from ne ct.
/ Landscape rake power angle question #4
Junkman,
Your wanting to do the very same thing that I would like to do to my Landpride rake. Please keep us posted as to your progress.
I was thinking of devising a way to use my snowplow cylinders to angle my rake. Use them on my rake in the summer and put them back on my snowplow for the winter.
I haven't taken time lately to think the process through.
I thought of this also, but I don't know if it will work because of the design of the hydraulic valve. The snow plow pistons are single port pistons. Also, some snow plow pumps operate at a lower PSI, so I don't know how well the cylinders will hold up to the tractor hydraulics.
Merlo MF34.7 CS (A62177)
Merlo MF34.7 CS...
EZ Trail 3400 (A63688)
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
2005 Peterbilt 378 Day Cab w/ Wetline 834826 (A62613)
2005 Peterbilt 378...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
