Land "smoothing" job ... big ruts... best options?
   / Land "smoothing" job ... big ruts... best options?
6 ft discs, or larger? (48 HP hydro)
   / Land "smoothing" job ... big ruts... best options? #12
   / Land "smoothing" job ... big ruts... best options? #14
Long ago what I saw most often, when changing from row crops to flat planting, was a Cat D6 with a large offset disc working at about a 45 degree angle to the furrows.
Bruce
   / Land "smoothing" job ... big ruts... best options? #15
You shouldn't need to go across the furrow or ruts. Just disk with the direction of travel when they made the ruts and any heavy disk should fill in the ruts and knock down the beds. It may take a couple of passes if the vegetation is heavy. On the second pass, straddle the disk furrows and if more is needed after two passes, cut it on a diagonal. After two passes it should be smooth enough to go crosswise. A tandem drawbar pull is going to be better cutting and easier to pull but a 3 PH style will work as long as it is heavy box frame with large diameter blades (20-24")
   / Land "smoothing" job ... big ruts... best options? #16
I would run a chisel plow over it to bust up the ground, and it will somewhat level out the rows. Then, once the ground is busted up, I'd disk it with a tandem disk or, even better, an offset disk.
You run the chisel plow lengthwise with the rows (i.e., in the same direction as the rows, not across them). Trying to plow across them will beat you and your tractor to death.
Back on the farm whenever we were changing a piece of land from a row crop with beds (such as cotton) to a non-row crop (such as wheat), that's what we did.
This is likely the best way, but most of us don't have unlimited access to farm equipment and hardly any CUT owner will have a chisel plow. I think a tandem disk with possible a heavy drag behind it will suit the situation just fine and not have to have multiply pieces of equipment
Ok, so you're saying that a pull behind disc works better than a three-point disc. But, how do i transport the pull behind disc there? Its about 30 miles away. I figure a 3 Point disc would be easy to haul with the tractor on my trailer.
If I go with a three-point disk for mobility, you think I'd be able to handle an 8 foot disc okay?
   / Land "smoothing" job ... big ruts... best options? #18
Three Point Hitch Mounted Disc Harrows:
If you want to disc close to fence rows, get a disc 12" wider than outside tire width, so each side of disc sticks out 6".
If you need to trailer tractor/disc combo, get a disc no wider than outside tire width.
If you will prepare food plots in rough ground, get a disc 12" NARROWER than outside tire width.
Mounted Disc Harrows improve tractor traction, like all Three Point Hitch mounted implements, by transferring implement weight to tractor rear tires.
   / Land "smoothing" job ... big ruts... best options? #19
My vote is disk it with the rows then against the rows. Two total times across the land. Drag some railroad ties behind the disc with heavy chain if you have access.
Brett
   / Land "smoothing" job ... big ruts... best options? #20
Second passes with Disc Harrows are most effective at 45 degree angle, not 90 degree angle.
The disc pans will be deeper, dirt will be flying and your tractor will be grunting in HST/MED + throttle.
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
Kubota RTV-X900 Utility Cart (A56857)
Kubota RTV-X900...
2017 Chevrolet Impala (A56859)
2017 Chevrolet...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2017 Ford Explorer (A56859)
2017 Ford Explorer...
