Land Pride snowblower problems
/ Land Pride snowblower problems #1
tdrsteve
kamiah Idaho
kubota 4700
I bought a new Land Pride SB 1064 snowblower. When it works it works well but it I noticed that the idler sproket was off and then upon further examination I found that the auger drive chain was not in line causing the problem with the sproket. The wing that is welded onto the frame and holds the drive shaft and sprokets was not aligned proberly from the factory. I spoke with the factory and was told to use clamps or a come along to pull the frame into alignment as this is not uncommon with this unit. Has less than 3 hours of use. My question is it seems to me a gusset or brace of some sort is needed for extra strength and after 3 hours of use and it needs to be rebuilt and then told how to rebuild it, seems odd. Has anyone else run into this? Thanks
/ Land Pride snowblower problems #2
I would take it back to the dealer and get another one.
/ Land Pride snowblower problems #3
Not into this specific issue but I have done more than my share of whacking parts back where they belong on new equipment isntead of returning it. Depends on how badly you need it and if to you it's a consumer item or a work-related item. Tractor implements are not the same as autos or electronic equipment, it's considered a bit rough around the edges even when new and sometimes certain owner "adjustments" are required.
