Posthole Digger Land Pride PD10 on Kubota B7510
   / Land Pride PD10 on Kubota B7510 #1
johnmcda
Atlanta, GA
Kubota B7510
I need more down pressure on the Land Pride PD10. They make a down pressure kit for it.
Anybody know if I have to also install an additional valve to actuate the down pressure cylinder on a Kubota B7510?
   / Land Pride PD10 on Kubota B7510 #2
:welcome:
   / Land Pride PD10 on Kubota B7510 #3
Yes you need hydraulics from somewhere.
Thanks.
I understand I need to hook up to the aux hydraulic port, but I didn't know if the down pressure kit had its own control valve.
   / Land Pride PD10 on Kubota B7510 #5
yes you need a valve.
   / Land Pride PD10 on Kubota B7510 #7
It is a single acting hydraulic, so you will need a drain to tank connection also. The kits are great, but you do need all the correct connections.
I knew I had to supply the return line but now I'm going to have to find the appropriate valve as well.
2013 Chrysler 200 Sedan (A50324)
2013 Chrysler 200...
2010 KMC 3376 Peanut Combine (A52748)
2010 KMC 3376...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
Mower King Q.A Pallet Forks (A50121)
Mower King Q.A...
2013 Ford Escape SUV (A50324)
2013 Ford Escape...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
