Dec 24, 2012 / Land Pride PD10 on Kubota B7510 #1 J johnmcda New member Joined Dec 23, 2012 Messages 4 Location Atlanta, GA Tractor Kubota B7510 I need more down pressure on the Land Pride PD10. They make a down pressure kit for it. Anybody know if I have to also install an additional valve to actuate the down pressure cylinder on a Kubota B7510?
Dec 24, 2012 / Land Pride PD10 on Kubota B7510 #2 murphy1244 Super Star Member Joined Nov 25, 2011 Messages 19,509 Location Ohio Tractor Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y :welcome:
Dec 24, 2012 / Land Pride PD10 on Kubota B7510 #3 murphy1244 Super Star Member Joined Nov 25, 2011 Messages 19,509 Location Ohio Tractor Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y johnmcda said: I need more down pressure on the Land Pride PD10. They make a down pressure kit for it. Anybody know if I have to also install an additional valve to actuate the down pressure cylinder on a Kubota B7510? Click to expand... Yes you need hydraulics from somewhere.
Dec 24, 2012 / Land Pride PD10 on Kubota B7510 Thread Starter #4 OP J johnmcda New member Joined Dec 23, 2012 Messages 4 Location Atlanta, GA Tractor Kubota B7510 murphy1244 said: Yes you need hydraulics from somewhere. Click to expand... Thanks. I understand I need to hook up to the aux hydraulic port, but I didn't know if the down pressure kit had its own control valve.
Dec 24, 2012 / Land Pride PD10 on Kubota B7510 #5 murphy1244 Super Star Member Joined Nov 25, 2011 Messages 19,509 Location Ohio Tractor Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y yes you need a valve.
Dec 24, 2012 / Land Pride PD10 on Kubota B7510 Thread Starter #6 OP J johnmcda New member Joined Dec 23, 2012 Messages 4 Location Atlanta, GA Tractor Kubota B7510 murphy1244 said: yes you need a valve. Click to expand... Thanks
Dec 24, 2012 / Land Pride PD10 on Kubota B7510 #7 MtnViewRanch Elite Member, Advertiser Joined Mar 19, 2005 Messages 10,674 Location 4000\' mountains of Southern California Tractor Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6, It is a single acting hydraulic, so you will need a drain to tank connection also. The kits are great, but you do need all the correct connections. Attachments PB040025.JPG 104.1 KB · Views: 259
Dec 24, 2012 / Land Pride PD10 on Kubota B7510 Thread Starter #8 OP J johnmcda New member Joined Dec 23, 2012 Messages 4 Location Atlanta, GA Tractor Kubota B7510 MtnViewRanch said: It is a single acting hydraulic, so you will need a drain to tank connection also. The kits are great, but you do need all the correct connections. Click to expand... I knew I had to supply the return line but now I'm going to have to find the appropriate valve as well.
