Posthole Digger Land Pride PD10 on Kubota B7510
   / Land Pride PD10 on Kubota B7510 #1
johnmcda
Atlanta, GA
Kubota B7510
I need more down pressure on the Land Pride PD10. They make a down pressure kit for it.
Anybody know if I have to also install an additional valve to actuate the down pressure cylinder on a Kubota B7510?
   / Land Pride PD10 on Kubota B7510 #2
:welcome:
   / Land Pride PD10 on Kubota B7510 #3
Yes you need hydraulics from somewhere.
Thanks.
I understand I need to hook up to the aux hydraulic port, but I didn't know if the down pressure kit had its own control valve.
   / Land Pride PD10 on Kubota B7510 #5
yes you need a valve.
   / Land Pride PD10 on Kubota B7510 #7
It is a single acting hydraulic, so you will need a drain to tank connection also. The kits are great, but you do need all the correct connections.
I knew I had to supply the return line but now I'm going to have to find the appropriate valve as well.
2015 Ford Escape SUV (A51694)
2015 Ford Escape...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A55314)
Koyker Loader...
2017 Kubota M7-151 Premium MFWD Tractor (A55314)
2017 Kubota M7-151...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2006 International 9400i (A55302)
2006 International...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
