LA703 Loader valve problems
/ LA703 Loader valve problems #1
Chad170
Crestline CA
Kubota B6000
Hey there y'all smart move but I didn't look at the lines when I disconnected my loader valve..tried hooking it back up its got what I thought was pressure, relief, and power beyond..
But anyways come to find out that's not the case one port is labeled "P" next "BY" and the third isn't labeled..when I tired hooking it up the way it seems like it should go, the up and down part of the loader is backwards..
And on the tilt side it's got pressure coming out of both houses trying to push both sides of the tilt cylinder at the same time..
Cracked my pump and blew a hose trying to figure out what's up with the binding tilt side
Any help what the the labels are and the unnamed port is?
/ LA703 Loader valve problems #2
Pretty sure P is for pressure or pump, either way same line that feeds the valve. BY I think would be power beyond that goes to the next valve in line. That leaves the unlabeled port to be the return line that goes to the tank.
Someone correct me if I'm wrong.
The pressure out of both hoses is for the regenerative cycle or "quick dump". Sounds like maybe you've got the pump line plumbed into the wrong port.
/ LA703 Loader valve problems #3
A B6000 would be unlikely to have regenerative cycle for loader valve I am thinking. That is an old model Kubota. I could be wrong and ask for a picture or two be posted.
Dave M7040
Truck Tool Box (A65640)
Truck Tool Box...
Bucket (A64194)
Bucket (A64194)
Landhonor Adjustable Rolling Creeper Stool (A66408)
Landhonor...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
Mini Universal Tree Spade (A65640)
Mini Universal...
