La680
/ La680 #1
darwinkelsall
63 b414 65 b414 56 300 utility 55 300 utility 55 fordson major 40 miniapolis zts
Hi there, does anyone know of a kit to rebuild a b01301 control lever on a la680 loader, pretty much all the pivots are worn out, it's on a l4200 no cab, I know I can buy all the parts from the dealer but was looking for a complete kit, or if anyone has any better ideas, just to note that there isn't anything wrong with the spool valve assembly itself, just the linkages.
Thanks in advance
Darwin
/ La680 #2
Don't know of a kit - but I had a LA680 with a floppy lever which I improved a lot by replacing the 010 lever. The pin holes were egged out. I also replaced the 120 lever but the 010 made the biggest difference. The price for 75540-62110 is over $150. One might try welding and re-drilling the old part? Good luck - Dick B
  • LA680 lever.pdf
/ La680
Thanks for the reply, if it were mine I'd weld, grind, drill, hammer, curse etc but it's a friend's and gets used several times a week so can't really do it at my leisure, that's why was hoping for a kit or if someone succefully changed to a different lever, can't say I'm a big fan of this style, all my loaders are old enough that they are run with 2 levers, are all the joysticks as awkward to use as this one and wear out as fast? Or is this one just a bad design? Tractor has just under 3k hours on it
UNUSED RAYTREE RMA42 HYD AUGER (A62131)
UNUSED RAYTREE...
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
2025 JMR 72in. Hydraulic Dual Cylinder Brush Grapple Skid Steer Attachment (A61567)
2025 JMR 72in...
DIRT DOG SBX72-72" BOX BLADE W/TEETH (A62130)
DIRT DOG SBX72-72"...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
New/Unused Receiver Hitch (A61166)
New/Unused...
