Loader LA403 loader on B7800?
/ LA403 loader on B7800? #1
Dixie B6000
Kubota B6000
Will a LA403 loader for the B3030 fit on a B7800. If not a direct fit how much modification will it require if at all possible?
/ LA403 loader on B7800? #2
If the frame is the same on the B3030 as it is on the B7800 it will fit. If you are trying to use parts from both it will not. The LA403 Loader is narrower than the LA402 but does have bucket stops that the LA402 lacks. Hope this helps.
Im not sure about the frame. Hoping someone can chime in who has more knowledge about it.
/ LA403 loader on B7800? #4
I've done a lot of checking this and I cannot find an instance where the LA403 loader was mounted to the B7800 tractor. I will be calling my dealer in the morning! NOW I want to know for sure. Thank you!
I called my dealer today. They said the only loader listed for the B7800 is a LA402
/ LA403 loader on B7800? #6
I just looked at the parts on the 402 and the 403 loaders. The 7800 it showed 3 sub frames, the 3030 even bolts up different. so I would guess not.
/ LA403 loader on B7800? #7
Thanx, you saved me a phone call!
Guess that settles that. :)
UNUSED CFG KKT (A)27 STAND-ON SKID STEER (A64280)
UNUSED CFG KKT...
John Deere 15' PT Batwing Mower (A64126)
John Deere 15' PT...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
2004 International 4400 Flatbed-Dump (A62613)
2004 International...
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
1995 John Deere 7400 (A60462)
1995 John Deere...
