Loader La344 loader
/ La344 loader #1
Wvanatti
John Deere 2305 (2010)
I have a BX 2380 30 hours on it. Got it after my Dad passed.
I ordered a LA344 loader. Delivered on a pallet. Installed myself. It took a little work to get the right side to lock in. Took it off, set in barn for a year. Put it on yesterday. Right arm never would lock. Finally pry’ed it with a screwdriver to get it to lock. Bucket has never been used.
Thinking back on installing the arms to frame, I tightened everything up an torqued per instructions. Now that the bucket is locked on, thinking of loosing the bolts. Then re torque. Maybe just not aligned correctly.
I’m use to my JD2305 bucket.
Anyone else had a similar issue or a remedy ? Thanks for any advise. Bill
/ La344 loader #2
Well, kind of. We have a BX2200 bought nearly new back 20 years ago. The LA211 loader has always been "sprung" it seemed to me. I assumed the prior owner (who was worse than ignorant of tractors or mechanisms...) probably found a way to bend the loader frame. Over the years I found that when installing the loader back onto the fixed frame (frame staying on the tractor of course) I can put a 2x4 under the far right corner of the bucket on a nice flat concrete floor and lower the loader using the (already hooked up) hydraulics. In effect I am applying torsion and "spindling" or twisting the loader frame. Playing with that configuration a little I can get the pins to line up and finish attaching the loader. It is entirely possible it was not bent but has always been that way.
I do not see where mine would change angle enough to matter if all the bolts were loose. Worth a try I guess. Is 'getting the pins in' what you are calling 'locked?'
/ La344 loader
Thanks for the reply. My LA344 loader doesn’t have a pin. I’ve seen that on YouTube. On this one, once it’s down in the bottom cradle, there is a lever you move down to locked position. Left goes easy. Right is close but won’t go. I disconnected and pulled in 5 times an tried. Watched several videos. It just won’t lock. Tried a board under each side of stand to try- no difference. When I say pry with a screwdriver. It’s a 18” big screwdriver. And 30-50LBS of force. Been easiest if I would have grabbed my 3’ crow bar. Once on, everything looks straight. Nothing looks bent. Was nicely shipped on pallet.
This attempt to put on -is on a level concrete floor.
/ La344 loader #4
Once it is mounted and locked, is the left locking lever still relatively loose (or at least you can unload the FEL to where it is easy to move) while the right one is tight? Can you move the loader position in any way where the right one gets loose? No amount of chocks under the bucket get it to where the right side is loose?
If not I guess it is worth a try to loosen all the frame mounting bolts and while they are loose repeat to see if you can find a spot that relieves the right lever stress. If you do of course tighten all the bolts. I'm doubtful but it can't hurt to try.
/ La344 loader
Thanks again for advise. Once locked in. Both locking levers are tight, can’t be moved out of notch to unlock. Bucket seems to function correctly. Still haven’t used the bucket. Still has perfect paint :0
I’m off Thursday. I’ll play more with it then. Maybe post a video if I don’t have any luck.
  • Good Post
Reactions: JWR
/ La344 loader
Just realized my last post wasn’t clear. Now that it is locked in. Levers are tight an won’t unlock. Once bucket lifts front tires off, both unlock. But, to then re-lock. Left easy, right side has to be pried back down to lock. Even though the bracket really hasn’t moved, just pressure off. Very odd.
/ La344 loader #7
Yeah, really! With that clarification it is VERY odd. Of course I'm still interested to hear what you find when you loosen the loader frame bolts.
/ La344 loader
I’ll certainly post back Thursday after I try it. Doing searches, it appears this is a common issue. Most state level bucket is key. I’m pretty mechanical, I’ve measure arms, pivot points etc with the loader off. All equal. We shall see.
/ La344 loader
Made a descent video, won’t let me attach. This is the lever that won’t lock in. ( pic of left side). Right side is the one that won’t lock with out force from pry bar.
/ La344 loader #10
Oh Geez. That is much newer hardware than mine. I have no experience with that at all. Just curious, I see 2 levers each with a black handle tip. Which one is it that won't lock for you? [I realize your photo is left side hardware. Mirror image of the other side no doubt.]
/ La344 loader
The bottom Left is lever is the one that locks. Top right is once locked. Lift bucket, roll an stow kick stand. Right side only has on lever for lock.
/ La344 loader #12
I'm sorry but I am not following you -- "Top right is once locked." What does that mean? Maybe a typo?
/ La344 loader
I’m the worst at multi task…
On the left side of loader arm, there are two levers. Bottom is for locking on. Top is for stowing kick stand.
On the right side of loader arm, only one lever. -Just for licking on. Right side is the one I’m having issue with.
/ La344 loader #15
You know... I was just thinking about things that involve fits this morning. About things that are generally made in the same class as your loader fit up. In my working life as an engineer I designed more things that worked than didn't... but not everything worked right. Some of it wasn't a good design, and somewhat more were simply not built to specs.
One, don't ever tighten everything down until the installation is complete and working. Then you can go around and torque it. That goes for pretty much anything that needs fitting. And it might even work.
Two, don't expect everything to just immediately work with hand pressure. That's unrealistic these days. Especially so for anything built with formed and welded metal. We used to shape and weld metal in house using jigs. That gave us control over forming stresses. Today metal subassemblies are made all over the world and then shipped to a final weld and assembly point. The tolerances & errors cannot help but stack up.
Three, you do have a workable solution. You could consider mounting an 18" prybar somewhere handy and call it done. Or make it into a project and reshape that mount. But I agree: loosen and re-torque first.
rScotty
/ La344 loader
rScotty
Thanks for the reply. While I’m certainly not an engineer, just a back yard mechanic. I always loosely assemble things to ensure bolts align before tighten. I’m this case, I didn’t - so, why I was thinking the same thing. I’m thinking while welding in he jig, metal was allowed to cool after taking out. Maybe sprung a bit. It’s so incredibly close. My Dad had purchased this unit without the loader. It was cheapest to have delivered on a pallet an I assemble an put on. What could go wrong. It’s on my to do list today. I’ll reply when done.
/ La344 loader
Update***
I have the bucket locked in. Bucket level on concrete floor. Loosened all the bolts on bracket to frame. Left side immediately dropped 1/8-1/4 inch. Once all loose. Took my dead blow mallet an hit a few times on the top ( both sides). Retighten, torqued.
Took bucket off 3 times, backed away an put back on. Both sides locked in easy. So I’m saying that was it. 🤞. From what I can tell. Anyone ever has this issue, worth the time to give it a try.
Thanks to all for the input an moral support. Bill
  • Good Post
Reactions: JWR
/ La344 loader #18
Update***
Great news. Good to hear it is taken care of.
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
UNUSED FUTURE HYD THUMB CLAMP -D60450 (A60432)
UNUSED FUTURE HYD...
2006 CATERPILLAR 420D IT BACKHOE (A60429)
2006 CATERPILLAR...
8' DISC HARROW (A60430)
8' DISC HARROW...
2021 SANY SY365C9C5K (A58214)
2021 SANY...
CAT 312C EXCAVATOR (A58214)
CAT 312C EXCAVATOR...
