LA 504 FEL Hydraulic Issue...
   / LA 504 FEL Hydraulic Issue...
Initial thought is the quick disconnect is starting to go bad. They can act like check valves and prevent flow in one direction. On a loader the hose should purge just by cycling the cylinders full travel both directions.
Hoses fail or blow for potentially several different reasons like age, chaffed on something, to tight of bend radius, fatigue from repeated pressure spikes, etc.
You are absolutely 💯 correct! Changed the quick disconnects and what do you know, problem solved! I have to wonder if that 🤔 may have caused the hose to fail?
  • Good Post
Reactions: JWR
   / LA 504 FEL Hydraulic Issue... #12
Gltrap
Thanks for letting us know what the resolution was and glad you now have a working machine.
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A58018)
2020 INTERNATIONAL...
Skid Steer 43" Disc Mulcher (New/Unused) (A59225)
Skid Steer 43"...
More info coming soon! (A55787)
More info coming...
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2018 Freightliner M2 106 AWD Terex Hi-Ranger TC55 55ft. Insulated Material Handling Bucket Truck (A55973)
2018 Freightliner...
