LA 504 FEL Hydraulic Issue...
   / LA 504 FEL Hydraulic Issue...
Initial thought is the quick disconnect is starting to go bad. They can act like check valves and prevent flow in one direction. On a loader the hose should purge just by cycling the cylinders full travel both directions.
Hoses fail or blow for potentially several different reasons like age, chaffed on something, to tight of bend radius, fatigue from repeated pressure spikes, etc.
You are absolutely 💯 correct! Changed the quick disconnects and what do you know, problem solved! I have to wonder if that 🤔 may have caused the hose to fail?
  • Good Post
Reactions: JWR
   / LA 504 FEL Hydraulic Issue... #12
Gltrap
Thanks for letting us know what the resolution was and glad you now have a working machine.
2019 Ford F-350 4x4 Flatbed Truck (A55788)
2019 Ford F-350...
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
Mini -Excavator Heavy Duty Rock Ripper (New/Unused) (A59225)
Mini -Excavator...
(2) OIL DRUMS & PUMP (A58374)
(2) OIL DRUMS &...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A58018)
2003 FORD F150...
1957 Chevrolet Bel Air - 2-Door Hardtop, Period-Correct Engine (A56435)
1957 Chevrolet Bel...
