LA 504 FEL Hydraulic Issue...
   / LA 504 FEL Hydraulic Issue...
Initial thought is the quick disconnect is starting to go bad. They can act like check valves and prevent flow in one direction. On a loader the hose should purge just by cycling the cylinders full travel both directions.
Hoses fail or blow for potentially several different reasons like age, chaffed on something, to tight of bend radius, fatigue from repeated pressure spikes, etc.
You are absolutely 💯 correct! Changed the quick disconnects and what do you know, problem solved! I have to wonder if that 🤔 may have caused the hose to fail?
  • Good Post
Reactions: JWR
   / LA 504 FEL Hydraulic Issue... #12
Gltrap
Thanks for letting us know what the resolution was and glad you now have a working machine.
Grecer Food Trailer (A55973)
Grecer Food...
2022 Chevrolet Tahoe SUV (A56859)
2022 Chevrolet...
Case-IH 160 Puma (A57148)
Case-IH 160 Puma...
New/Unused Electric Golf Cart (A57453)
New/Unused...
MASSEY FERGUSON SEAT (A58374)
MASSEY FERGUSON...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
