LA 1001/LA 1002 loaders
/ LA 1001/LA 1002 loaders #1
design
Southern, NH
M5400
There is a 2nd set of 1/2"x2"x24" steel brackets attached to the frame. The 1st set is used to keep the loader upright when it is not installed on the machine. What is the 2nd set used for?
One end has a 1/2" diameter pin and the other end has a slot.
-Design
/ LA 1001/LA 1002 loaders #2
Some loaders have just a single pair of support arms - other models use two arms on each side. On my LA1150 the pieces with the slot and pin are part of the support when the loader is removed. The slots fit over pins welded to the loader frame.
Pic above is doctored to show approx arm locations.
2007 (INOPERABLE) INTERNATIONAL DURASTAR 4300 (A67714)
2007 (INOPERABLE)...
2013 VOLVO A40F OFF ROAD DUMP TRUCK (A65053)
2013 VOLVO A40F...
PALLET OF HOSE FITTINGS AND HEAVYEQUIPMENT PARTS (A68842)
PALLET OF HOSE...
2017 HINO 195 4X2 S/A  16FT BOX TRUCK (A69167)
2017 HINO 195 4X2...
2007 PETERBILT 379 (INOPERABLE) (A67714)
2007 PETERBILT 379...
2025 Kubota RTV520 4x4 Gas Utility Cart (A66734)
2025 Kubota RTV520...
