L6060 tool box options
/ L6060 tool box options #1
Complete Turf Care
South Louisiana
2022 Kubota Grand L6060 (no loader), 2017 Kubota Grand L6060, 2011 Kubota L5740 HSTC-3, 1997 Kubota M4700
I recently purchased a L6060 with a cab and it does not come with any kind of tool box, nor does Kubota offer any tool box option.
I'm wondering what other L6060 have done, if anything, for a tool box.
I also own a L5740 that has a small box behind the seat and although it doesn't hold much, it is handy. The cab on the new tractor has more room inside, but there is no place to store a few tools and hitch pins and such.
/ L6060 tool box options #2
Do you have a loader on it?
/ L6060 tool box options #6
Try and grasp the concept of forum "Search".
At the very least, look at the "Similar Threads" at the foot of this page.
:rolleyes:
/ L6060 tool box options #7
I made a pair of these for my MX5800 and found they fit the L6060 as well. In my case, the FEL hyd. lines run through the right side tube so I can only use one on the left. The trays also fit the cross tubes of many FEL's but the contents move around as the FEL is raised and lowered. Ok for water bottles, cans of chain saw fuel, etc. but not good for fragile items.
They are fairly easy to make from some sch 80 PVC pipe and fittings available at Home Depot. Some sanding is necessary for a good fit:
The trays are a press in fit and I've never had one come loose but if you're worried about it, you can always do something like this:
That is what I did on my JD. Works great. Do paint the ammo can very well. Maybe prep it very well. I like it is sealed keeps the dust out.
I like the idea of an ammo box. They are big and easy access. Do you have any pics of yours?
I remember seeing this. In fact, I told the Kubota salesperson about these. I'm gonna try this too.
Thanks!
/ L6060 tool box options #9
:rolleyes:
I have a L4060hstc, so basically the same tractor other than engine. I've been keeping my eye out for good toolbox option for over a year & have used search a fair bit. Other than the loader tube slide in pipe thing I haven't seen one. So saying use the search button isn't always an option.
/ L6060 tool box options #10
I keep a canvas tool bag behind the seat. I have always liked the idea of using the loader cross tubes and bdhsfz6 has done a nice job. What I need now is a storage space for 2 sections of 3/8 chain. The tube that goes completely from arm to arm has enough room, but I always get stuck at how to close the ends off.
/ L6060 tool box options #11
I agree and often starting a new thread brings out newer ideas that were tried by members after the search results but never posted.
/ L6060 tool box options #12
I built a "chain box" and fastened it to the FEL mounting bracket. It's very handy for chains, clevis, hitch pins, etc. Drilled holes in the bottom to let out water and most debris. I originally tried expanded metal in the bottom but the holes were too big and the chain would get caught in them.
For some reason I can't post pics right now. I'll come back later and add some.
/ L6060 tool box options #13
gona use tap a talk to post a pic of a mod here......so go to the next post (with luck). ;)
/ L6060 tool box options #14
Saw this from a post on “Farm Show” and gave it a whirl in my L805 loader. Had to sand the plastic cap on the OD a bit...but was able to friction fit them with a few taps of a hammer. The cap has an expanding feature that is water and dust proof. Not huge, but can hold a chain or a few pins or tools. I also attached a Kolpin shotshell holder (belt carrier for trap shooting ) to the bar below the windshield. It holds lots of stuff for me.
Got everything I needed at the pluming section at Menards.....for about $14. Not too shabby....and it hold more than it looks.
/ L6060 tool box options #15
View attachment 524560 View attachment 524561
View attachment 524562 View attachment 524563 View attachment 524564 View attachment 524565 View attachment 524566
That if freaking beautiful!! Nice job!
2015 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2015 PETERBILT 579...
2025 Pabreak Hydraulic Rotary Tiller Skid Steer Attachment (A61567)
2025 Pabreak...
2019 CATERPILLAR 305.5E2 CR EXCAVATOR (A62129)
2019 CATERPILLAR...
2000 Thomas Built Saf-T-Liner Transit Passenger Bus (A61568)
2000 Thomas Built...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
