L6060 Fuel Usage
/ L6060 Fuel Usage #1
SDT
Veteran Member
SE Indiana
Multiple Fords and Kubotas
When I bought my L6060 I was aware that, being a hydrostat and a large one, it would be thirsty, and it is. Moreover, it appears to make little difference how heavily it is loaded as about 2,400 engine RPM is needed to maintain 540 PTO RPM.
What king of fuel consumption are you other owners seeing?
SDT
/ L6060 Fuel Usage #2
At FULL load the L6060 should consume approximately 3.0-3.5 gallons per hour. Philip.
/ L6060 Fuel Usage #3
I believe L6060 fuel consumption is influenced more by the engine turbocharger, mechanically forcing air and fuel into the engine, than the HST transmission. The air is 'free' you pay for the fuel.
The L4060 has 148.5 cubic inch engine generating 42 gross horsepower.
The L6060 has 148.5 cubic inch turbocharged engine generating 62 gross horsepower, about 50% horsepower increase and 50% increase in fuel consumption.
/ L6060 Fuel Usage
/ L6060 Fuel Usage #5
According to the charts Kubota Engine Division publishes, the 6060 direct injection engine uses about 20% less fuel than the 5740 indirect injection engine. I will use 4 on my 5740 if I am really working hard.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
1996 International Water Truck with a Caterpillar Engine (A61306)
1996 International...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
UNUSED 2026 INDUSTRIAS AMERICA HYD TILT TRAILER (A60430)
UNUSED 2026...
Towable Centrifugal Water Pump (A59228)
Towable...
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
